OpenPort 2.0/Evoscan problem
Postby Thane » Sun Jan 04, 2009 2:02 am
Has anyone encountered the same problem as me, when using Tactrix OpenPort 2.0 you can not connect to Evoscan.
Is there anyway around this problem???
Thane
Thane
Re: OpenPort 2.0/Evoscan problem
Postby brucer » Sun Jan 04, 2009 7:08 am
as far as I know evoscan isn't ready for OP2. I Think his next offering 2.6 will work. Its in beta testing now, should be soon.
brucer
Postby Thane » Sun Jan 04, 2009 7:51 am
Hi brucer
Evoscan did give me Evoscan 2.6 Beta, is still does not work.
Last communication from Evoscan was to purchase their cable, is there any other logging software which will work with OpenPort 2.0??
Thane
Postby brucer » Sun Jan 04, 2009 2:06 pm
I know some tuners are already tweaking the evoX ecu with OP2, so they must be logging in order to tune.
If you go on the evolutionm.net. Look for posts by razorlab, he has had some success and it must be with 2.6. As to which cable he is using, I don't know.
if you have an VIII, IX, it might be easier to borrow a cable
but otherwise there isn't anything else for OP2, unless you have a subie.
brucer
Postby brucer » Sun Jan 04, 2009 7:01 pm
are you able to connect to ecuflash with the OP2?
brucer
Postby Thane » Thu Jan 08, 2009 12:08 am
Hi Brucer
No still not possible, emailed Tactrix for support but so far no answer from them.
Thane
Thane
Postby gsxwingz » Fri Jan 09, 2009 10:28 am
PCMSCAN is another option to log EVOX with 2.0 cable which is what razorlab is using for logging.
gsxwingz
