Which Datalogging program for USDM 2002 WRX
Postby iambrentdaniels » Thu Jan 01, 2009 8:45 pm
Hey everyone. I've really been struggling with logging tonight. I attempted for a few hours with no sucess. Which connections do I need in place under the dash in order to log my 2002 USDM WRX? And which program should I use to log? I tried romraider and ecu explorer, but had no sucess.
Please help!!!!
iambrentdaniels
Re: Which Datalogging program for USDM 2002 WRX
Postby Freon » Sat Jan 10, 2009 8:52 am
There are no special connections and you should NOT connect the green test connector to log. Just your laptop, Tactrix cable (any version should work on a 2002 WRX), and Ecuexplorer or Romraider or Ecuedit. The key must be in the Run position, but the engine does not have to be running.
I would suggest starting with Romraider. I would go to romraider.com and read the FAQ to start.
