I finally made the switch to EVOScan but, am having trouble with my LC-1 readings. I am able to connect with the LC-1 through EVOScan, however, the reading is in volts. I enabled the A/F ratio logger as well, which appears to have a calculation to convert the volts to a A/F ratio, however, all that is giving me is a steady 14.7?
I verified the LC-1 was reading correctly via LogWorks.
FYI - I'm using v2.5 EVOScan
