hi all, thank in advance for any clarification
1, sometimes during my logging, i get prolonged period on a recorded point, for example, i did a full run from 2500rpm wot to 7000 rpm, 3 times, on 3 separate logs, however on one of the logs, the rpm point stays on about 3900 and then jumps to 7000 missing all the in between data, any reasons for this?
2 sometimes when i measure hp i get silly number of 900+hp on a standardish car, any reasons i can fix for this?
3 How do i get the gauges to show live data to use while mapping? for example, if i would like to see gauges with the knock sum, rpm, speed, load, afr, tps, ignition advance, how would i set that up? cant seem to work it out
saying all this, its an amazing piece of kit and appreciate all the work thats gone into it, great for checking your car 25$ could save you 1000's!!
thanks
