when i start the datalogger the software go in exception.
The detail of the error are the follow:
Le informazioni su come richiamare il debug JIT (Just-In-Time) anziché questa finestra
sono riportate in fondo al messaggio.
************** Testo dell'eccezione **************
System.IndexOutOfRangeException: Indice oltre i limiti della matrice.
in MitsuLogger.x751922eb1bfae5fb.x9019a79b966d57d0(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
in System.Windows.Forms.Timer.OnTick(EventArgs e)
in System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Assembly caricati **************
mscorlib
Versione assembly: 2.0.0.0
Versione Win32: 2.0.50727.42 (RTM.050727-4200)
Base di codice: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
MitsuLogger
Versione assembly: 1.6.2640.35940
Versione Win32: 1.6.2640.35940
Base di codice: file:///C:/Documents%20and%20Settings/stefania%20catavere/Desktop/Mitsulogger%20v1.6%20Beta%203/MitsuLogger.exe
Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Microsoft.VisualBasic
Versione assembly: 8.0.0.0
Versione Win32: 8.0.50727.42 (RTM.050727-4200)
Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
AxInterop.MSScriptControl
Versione assembly: 1.0.0.0
Versione Win32: 1.0.0.0
Base di codice: file:///C:/Documents%20and%20Settings/stefania%20catavere/Desktop/Mitsulogger%20v1.6%20Beta%203/AxInterop.MSScriptControl.DLL
System.Windows.Forms.resources
Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_it_b77a5c561934e089/System.Windows.Forms.resources.dll
Base di codice: file:///C:/Documents%20and%20Settings/stefania%20catavere/Desktop/Mitsulogger%20v1.6%20Beta%203/Interop.MSScriptControl.DLL
System.Configuration
Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
Base di codice: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
mscorlib.resources
************** Debug JIT **************
Per attivare il debug JIT, è necessario impostare il valore
jitDebugging nella sezione system.windows.forms del file di configurazione
dell'applicazione o del computer (machine.config).
L'applicazione inoltre deve essere compilata con il debug
attivato.
Ad esempio:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
Quando il debug JIT è attivato, tutte le eccezioni non gestite
vengono inviate al debugger JIT registrato nel computer,
anziché essere gestite da questa finestra di dialogo.
