EvoScan v0.99 Released - Graphs / Alarms / Power&Torque
PostPosted: Fri Mar 30, 2007 9:33 am
by Evo4Mad
31st March 2007 - EvoScan v0.99 Released.
http://www.limitless.co.nz/EvoScan
The amount of work, programming, testing and EvoScan's 5,000 new lines
of code since v0.97 warrants the new version v0.99, and a big special
thanks to all the beta testers.
Check out just some of the 100s of new features: EvoScan v0.99
-Graph Log Item Favourites Lists
-Graph Templates supported
-New Alert/Alarm features
-1994/95 Mitsubishi FTOs supported
-Saves all settings for next use.
-Faster and better datalogging
-International support for regional settings with different decimal
representation.
-Remember Microsoft .net 1.1 and .net 2.0 are two different installers.
EvoScan uses .net v1.1 -Now supports Multiple FTDI USB devices in case
you are using an ftdi serial adapter for wideband logging also.
- EvoScan now has MultiByte logging support, which increases accuracy on
Load/RPM/AirFlow(MAF) (requires an ecu rom mod, because the factory
dealer scantool doesn't give that sort of accuracy out of the box)
- Logs Boost PSI/Bar for those replacing the factory MDP sensor with JDM
3bar boost sensors. (only select few vehicles have boost sensor logging)
- Full log graph zoom and scrolling support, horizontal and vertical
zooming. Note, horizontal zooming is available only after selecting it
in the right click menu.
- End User customizable chart/graph templates, adjustable graph series
colours. (DIY xml)
- When loading logs into the graph the log is scanned for acceleration
runs, and displays them in a nice list for you to pick from and
automatically zooms to that section for you to analyze. It scans the log
for positive acceleration for a number of seconds and displays the
number of log entries in the list also
- OnRoad Dyno Graphing and Logging. The Power and Torque graphs were
very technical and time consuming to implement, but EvoScan has taken a
shot at it, and it looks pretty good for a first version. EvoScan uses
MPH/KPH from the log file to determine your current gear for
power/torque calculations, if your vehicle can't log speed, then you can
still manually select the gear your power run was made with.
- I have gone through all the Evo 4/5/6/7/8/9 manuals and loaded all the
gear ratios and weights and drag co-efficients so that the power/torque
results can be more accurately determined. You can go into Vehicle
settings to select your vehicle, and if you have more specific details
for your vehicle weight and gear ratios you can enter these too.
- DataLogging alarms have been added, and custom alarm calculations can
be made with the inbuilt expression evaluator, for example you can now
have an alarm go off if a value goes over or below a specified value, or
a combination of criteria for your alarm, you can disable the alarm to
use later, or remove it all together. The alarms are saved to the
alarms.xml file when you close EvoScan for next use.
- Also I have been getting a number of questions about the EvoScan USB
cables that I make, the EvoScan 1.4E is a generic obdII datalogger cable
and the EvoScan 1.3M is both a datalogger and is capable of reflashing
mistubishi ecus.
EvoScan 1.4E USB OBDII DataLogger Cable
High quality and high performance datalogger cable, capable of extreme
high speeds.
Perfect for EvoScan, and supports all OBDII vehicles, mitsulogger, and
all openport software. Specifically supports ALL Mitsubishi vehicles for
datalogging - includes Pin1 grounded for full Mitsubishi diagnostic
support. This is a perfect datalogger cable where no ecu reprogramming
is required (ecu reprogramming is currently only available for
Mitsubishi Evos 7/8/9) http://www.limitless.co.nz/Cables/
EvoScan 1.3M USB OBDII Datalogger & ECUFlash Reprogramming Cable
high speeds.
Perfect for EvoScan, EcuFlash, and supports all OBDII vehicles,
mitsulogger, and all openport software. Specifically supports ALL
Mitsubishi vehicles for datalogging - includes Pin1 grounded for full
Mitsubishi diagnostic and datalogger support. and allows reprogramming
of Mitsubishi Evo5/6/7/8/9 factory ecus via EcuFlash and the included
white reflash connector.
Any feedback on this new version of EvoScan v0.99, please email
mailto:evoscan@limitless.co.nz.
Thanks for your support,
Hamish.
PostPosted: Fri Mar 30, 2007 11:49 am
by nvr2fast
I just downloaded it, and from the looks of it, it has TONS of new functions.
And a bonus for all non-USA cars, it has AYC monitoring as well!!! You can actually see kmph of the wheels and so on!!!
And of course, lots of other monitoring, and NOW the actual long-awaited DYNO function is available!!!
Of course, I haven't actually tried it yet, but it LOOKS very, very impressive!
If you haven't already purchased, now is the time! :D
