2001 Mitsu Spyder GT (now with flashable ECU)
laptop w/ Vista
Tactrix OBDII -> USB cable
EvoScan v.97
zeitronix ZT2 with wideband sensor
DB9 (serial) to USB converter (I have tried 3 different models)
I am able to log my AFRs using just the zeitronix software (will also log EGT, TPS, RPM). I am able to log ALL values under EvoScan EXCEPT for AFR. I have used Window's Device Manager to confirm I have the proper COM port selected for the wideband. I have adjusted the "Wideband" settings under EvoScan to use all the different options but it still won't log the AFR or even display the AFRs. I have tried the option of "log to wideband.csv" but no new file with that name is created.
Any thought on what I should try to get this working? If your is working could you post up what settings you are using? I have spent $750+ just to get a flashable ECU for my Mitsu and now I can't even get the proper logs so that I can move forward and tune this beast.... it sucks!!!
PLEASE HELP THIS NOOB!!!!!!
