Second Chance wrote:Thought this might help some, it needs ALOT more work. Feedback is welcome.
Needs .NET 2.0 framework
Mad If I could get your code, i'd like to make just a basic console logging program so I can try and get more speed in the logging department without all the updates etc.
3gturbo wrote:This program is very buggy it only installed on 1 out of 4 computers and the guy will tell you it's your windows problem. Thanks for returning my pm's and emails way to support your product. There is obviously something wrong with this software if it's still asking for .net 1.1.4322 when it's clearly installed.
fixem2 wrote:I am sorry, but everyone begged and begged for a release. When the product was released, he clearly stated "Pre-Release" hence the 0.7 version code. Now some people are declaring the software to be buggy and crap. No wonder people don't share their developments. Everyone needs to relax and let Evo4mad take in all the feedback. I think the program is awesome and one of the best logging programs for the money.
danl wrote:mad_viii wrote:I have a question about the three Fuel Trim readouts..
Not sure how to interpret the values, and these are of interest to me because my car has run lean for some time now even after installing a walbro fuel pump.
My readings at idle are:
Fuel Trim High: 99.84
Fuel Trim Low: 140.4
Fuel Trim Middle: 120.02
Not sure what these correlate to, last OBDII logger I worked with (not on the evo) reported long and short term fuel trims in + / - percent anything over 5% + or - would cause a DTC to be set
Anyone know what these valuse are and what the represent???
Those seem like values I am used to for DSM's, which doesen't surprise me as they are very similliar. At any rate your fuel trims are (rounding off).
Low 140%
Mid 120%
High 100%
It looks like your injector pulsewidth at idle is a little large. What this usually means when writing DSM ecu code is that your deadtime pulsewidth is a little large. I'd log your pulsewidth at idle and see what value you'd have to make your deadtime such that you reduced this pulsewidth by 40%. The goal is to bring the trims to 100%. You'll find that idle swings wildly so just try to get that one within 20% plus or minus. Try to get your mid within 10% plus or minus. You should be able to get your high fairly close. The idle typically changes drastically from day to day.
