SeanV wrote:Awesome stuff, downloaded installed this yesterday.
Very impressive here, well done.
Just a few questions from a Nooby.
My boost and maf gauges work 100%.
However, I can seem to get the correct values to appear for the...
EGT.
Knock.
IAM.
I have a AUS/SA MY03 WRX and I presume there is a place where I need to set the correct ROM addresses for scoobyview to pickup the information.
ECU Informatiom...
A4TE001I
Case ID = AF770
Only problem is I am not sure where to set them and what they should be set to.
Not to sure if this helps, I know from using ECUExplorer that my IAM is found at "020120" but other than that I am totally clueless.
Can somebody please point me in the right direction.
Thx.
SeanV wrote:
Bump, surely someone musy know how to do this.
Thx
SeanV wrote:SeanV wrote:Awesome stuff, downloaded installed this yesterday.
EGT.
Knock.
IAM.
ECU Informatiom...
A4TE001I
Case ID = AF770
Thx.
Thx
neutronium wrote:Switching to Celsius isn't very intuitive at the moment. You can open the param.txt file in the folder of the skin you're using and change the F's to C's. For example change EGTF to EGTC. Unfortunately you'll have to change the parameter line in the individual display's files. This should work fine for number displays but for bar displays you'll probably need to change their max and min values. Dial displays present more of a problem since the numbers are part of the background image. You would need to edit the image and probably reconfigure the angles. I'll work on an easier way to do all of this, probably some kind of global setting and dial gauges that automatically take care of labels and angles. I'll at least whip up a version of the skins that use celsius and bar by default.
Boost is currently only supported in psi. I'll add the option for bar.
Fuel Injector Pulse Width @ 0x000020 (value is * 0.256 to get ms)
To get ms to a % you must do the following:
(RPM * (ms / 1200))
Manifold absolute pressure @ 0x00000D (value is *37 then /255 to get PSI)
Manifold relative pressure @ 0x000024 (value is -128 then *37 then /255 to get PSI)
Mass Air Flow @ 0x000013 (high byte) 0x000014 (low byte) (value is then /100 to get g/s)
Exhaust Gas Temperature @ 0x000106 (value is +40 then*5 to get degrees C)
Intake Air Temp @ 0x000012 (value is -40 to get degrees C)
Knock Correction is @ 0x000022 (value is -128 then /2 to get degrees)
Coolant Temp @ 0x000008 (value is -40 to get degrees C)
(RPM * (ms / 1200))
