Mitsubishi Lancer Evolution 4/5/6/7/8/9 EvoScan Project v0.8
Postby the-moss2 » Mon Jun 26, 2006 9:51 am
ok, I'm going to try plugging both in tonight and see if it makes a difference.
the-moss2
Postby andenbre » Mon Jun 26, 2006 9:52 am
mike1023 wrote:is there any like pdf on how to get this data software going and use all the options in it. like a faq or a starter up
this is currently a prerelease so there is no documentation on it other than feedback that users post in the forums.
andenbre
Postby hexman » Mon Jun 26, 2006 9:54 am
I do not think that evo4mad if anyone knows what the load algorithm is. The closest I have seen is the Subaru formula:
g/4 cylinders charge = 120 * maf (g/sec) / rpm (rev/min) <-- Just as an FYI. That's the fomula used by the Denso ECU's and the SSM (Subaru Select Monitor) protocol, to calculate engine load.
Jorge (RiftsWRX)
www.ProjectWRX.com
Above is from EvoM.net http://forums.evolutionm.net/showthread ... ost3199606
I agree we need to know how this is calculated and be able to log it. This would help the tuning process immeasurably.
Up until now I hear a lot of speculation about load...
hexman
Postby Blak94GSX » Mon Jun 26, 2006 9:57 am
the-moss2 wrote:Evo 9 people, what sample rate are you getting?
I only plugged the ODB-II part of my tactrix cable into the car (not the prorammer part) and was getting around 15samples/s indicated on the software.
Should I be connecting the other connector also?
Run both cables connected. That puts the ECU into Diag mode instead of just regular OBDII mode. The switch only happens at startup, so you don't need the second plug attached once you are sampling data from the ECU, although I don't know why you would want to disconnect the plug...
Blak94GSX
Postby mike1023 » Mon Jun 26, 2006 9:58 am
sounds good to me also how come the log is does not keep rpm in one colum , and then timing in othere and tps and so on so its easyer to read the log.
is there someway to make it do that
mike1023
Postby andenbre » Mon Jun 26, 2006 9:59 am
I am hoping there is an actual value for load that the ecm will spit out like it has for rpm, ignition timing, ect... I think that this would be more accuate than a value calculated by the software its self.
andenbre
Postby andenbre » Mon Jun 26, 2006 10:05 am
what I do is tag the first set of samples then cut and past each set over to the right of the previous set over and over. it takes some time but you get a timeline of concurrent samples that you can follow better.
If you need a screen shot I can post to clear up my explanation
andenbre
Postby galvitron » Mon Jun 26, 2006 10:35 am
Paid, downloaded :D
Tested successfully with Windows 2000 Professional
Build 5.00.2195
Service Pack 4
.NET framework 1.1 installed (No 2.0 installed)
USB driver works fine
Evo4Mad, I just thought I'd mention this since you don't list it under supported OS list.
galvitron
Postby andenbre » Mon Jun 26, 2006 11:53 am
I think I figured out the timing issue when the ecu reports back 20 its actualy hex for 32 then subtract 10 and you get the 22 which is approx 10 degrees to high so if that factor is changed to "x - 20" that might be more accurate. what we need is someone with ecu+ to run a parallel log and compare the two logs for evoscan inaccuracys and find out exactly how far things are off
andenbre
Postby Blak94GSX » Mon Jun 26, 2006 12:23 pm
I have a variety of loggers at my disposal. I will compare the results and see if there is some consistency on the difference in timing reported.
Blak94GSX
Postby andenbre » Mon Jun 26, 2006 12:30 pm
what would be hot is if you (or any body else) could compare the other data logged that you can and let Evo4mad and the rest of know what is on target and how far anything else is off
here is a log that I edited out most channels and corrected the ignition timing to x - 20 and graphed it
edited pull charted.xls
(44.5 KiB) Downloaded 592 times
andenbre
Postby Blak94GSX » Mon Jun 26, 2006 12:32 pm
Yeah I'll post a bunch of log files from various systems for comparison tomorrow.
Blak94GSX
Postby Blak94GSX » Mon Jun 26, 2006 2:54 pm
The logger portion connects and samples data pretty well. I'm getting 120ish samples a second.
My only complaint so far is the data file format. Instead of writing out separate rows for each data element, can you change the data file to write out a field list at the top when a new log file is created, and then each of the data elements in a column. Something like this format which every other logger follows:
logsample.txt
(59.85 KiB) Downloaded 897 times
Blak94GSX
Postby Evo4Mad » Mon Jun 26, 2006 5:14 pm
Thanks I'll add this format as an option... but the timestamp is different between the first column and the end column which is the reason for the current format. I will cross tabulate the results and add use 2 columns StartTime / EndTime when using this format.
Blak94GSX wrote:The logger portion connects and samples data pretty well. I'm getting 120ish samples a second.
Postby c-spec » Mon Jun 26, 2006 6:34 pm
any release date on the fix for the timing table and other stuff?
c-spec
