Mitsubishi Lancer Evolution 4/5/6/7/8/9 EvoScan Project v0.8
Postby andenbre » Mon Jul 17, 2006 9:29 pm
Evo4Mad wrote:Its nearly there, another few hours of development and it will be all good to go. I am focusing on graphing as well as the playback(done) and gauges.
laakness wrote:Any word Evo4Mad on timing for the update with playback/gauges?
the graphing will be a good addition. cant wait to see if there are any other goodies coming in this release
andenbre
Postby laakness » Tue Jul 18, 2006 5:32 am
Cool, thanks.
laakness
Postby alwaysinboost » Wed Jul 19, 2006 1:54 pm
Any updates for us??
I check this page daily hoping for something... :D
alwaysinboost
Postby Evo4Mad » Wed Jul 19, 2006 2:47 pm
I did a couple of hours last night, and will again tonight.. making good progress. You'll get an email when its released.
Postby laakness » Thu Jul 20, 2006 7:51 am
Thanks again for the status update Evo4Mad
laakness
Postby S54fan » Sun Jul 23, 2006 10:28 am
As I posted on evolutionm.net, I've found what I believe to be the octane value at &H27 and the load value at &H38 (multiply by 1.25 to get load).
Postby danl » Mon Jul 24, 2006 1:37 pm
S54fan wrote:As I posted on evolutionm.net, I've found what I believe to be the octane value at &H27 and the load value at &H38 (multiply by 1.25 to get load).
Oh YEAH, that is SUPER important stuff to know!
danl
Postby HighPSI TSi Guy » Mon Jul 24, 2006 7:05 pm
Will Evoscan log with a old school standard ODBII cable as well? Or will it only work with the tactrix cable?
HighPSI TSi Guy
Postby S54fan » Tue Jul 25, 2006 12:17 am
&H27 seems to be definite. &H38 is actually my MAP sensor (3 bar on Evo IX JDM/UK) but it is close to load - and the scaling is 1.334x to get KPa - this is calculated from the factory service manual. Still looking for load, or high bytes of airflow if they exist.
Postby Evo4Mad » Tue Jul 25, 2006 6:12 am
Cool, can you find Vehicle Speed Sensor?
Postby S54fan » Tue Jul 25, 2006 9:01 am
I've gone all the way up to &H9F and not found the speed sensor.
I thought &H35 was another load candidate, but it clips.
&H32 seems to be the lookup value from the fuel map - on my UK/JDM ECU then modified by the lean spool settings by about 1 AFR.
Postby S54fan » Tue Jul 25, 2006 10:32 am
Evo4Mad wrote:Cool, can you find Vehicle Speed Sensor?
&H2F I think.
Can't find load though.
Can you comment if there are other access methods to snoop ECU data other than request ID - I've gone up to 9F and can't find a proper non-clipping airflow signal or load.
The nearest to tell me what zone I'm in (apart from checking the timing) is to read the value of the fuel map zone being accessed at &H32.
Postby HighPSI TSi Guy » Wed Jul 26, 2006 7:57 pm
HighPSI TSi Guy wrote:Will Evoscan log with a old school standard ODBII cable as well? Or will it only work with the tactrix cable?
anyone here know the answer? the creater of the program that just posted a bit ago, perhaps?
HighPSI TSi Guy
Postby chrisw » Thu Jul 27, 2006 11:32 am
no it will not. been there done that.
chrisw
Postby MalibuJack » Fri Jul 28, 2006 7:01 am
S54fan wrote:&H27 seems to be definite. &H38 is actually my MAP sensor (3 bar on Evo IX JDM/UK) but it is close to load - and the scaling is 1.334x to get KPa - this is calculated from the factory service manual. Still looking for load, or high bytes of airflow if they exist.
Can you PM me the part number on your sensor? I'll see if I can put one on a USDM evo and if it works..
MalibuJack
