laakness wrote:dudical26 wrote:Evo4Mad, could you include a log trigger button. For example with Subaru, the program starts and stops logging when you push the rear defogger button. This makes it easy to log while driving on the highway without having to look at your laptop.
Also is there any way to output the AF sensor as maybe AFR in addition to voltage?
What? I don't want my rear defrost on when I'm logging
MalibuJack wrote:c-spec wrote:it would be cool if we can have some source of dyno capability into the software.
Once Evo4Mad gets the new version out with the columns straightened out You can use Data Log Lab, the log files will import directly using a definition (and a definition file will likely be included in future versions of DLL) And you can do dyno runs in that. Its fairly accurate once everything is configured, and very consistent.. Until then, you can use my EvoScan Gateway tool I posted earlier, all it does is combine the seconds and time columns, then reformats the time so that you get a seconds from start of log.. And the logs can be days long, since I include the date (Day of year) in the calculation..
This won't be necessary after the new version is released..
Evo4Mad, I am a proficient programmer and would like to work on the program a bit, but I need the source code, I can help with development if you want to set up a members only source forge repository...
dudical26 wrote:Evo4Mad- While I have no programming skill, I have seen in the past that once these kinds of programs become open source, they progress much, much quicker and include lots of new capabilities. Are you considering releasing the source code? There are lots of people out there who REALLY appreciate what you have already done and want to contribute their knowledge.
alwaysinboost wrote:dudical26 wrote:Evo4Mad- While I have no programming skill, I have seen in the past that once these kinds of programs become open source, they progress much, much quicker and include lots of new capabilities. Are you considering releasing the source code? There are lots of people out there who REALLY appreciate what you have already done and want to contribute their knowledge.
I second that statement. Lets get the code out there at a minimum to a select few to help 'speed' this project along.
Evo4Mad wrote:UPDATE: As at Friday 14th July 2006, the registration cost for EvoScan will be $35US and will coincide for release version 1.0.
djmikeymike wrote:so if we payed the 15$ do we have to pay the difference to get the new version? i'm not bitching i just would like to know..... i would pay 50$ if i needed to for this product
