Mitsubishi Evo4-EvoX and Subaru EvoScan Datalogging Project
Postby MalibuJack » Sun Oct 01, 2006 5:17 pm
Evo4Mad wrote:Innovate LC1 support now working and tested, party time :) , thanks to Mike Laak for testing all my versions on his LC-1 ... If you are online a lot over the next few days and wanna be a tester for a whole bunch of new features I'm adding. add me to you msn... hamish.ahern at hotmail.com thanks.
A new version will be released (emailed) this coming weekend with all the new features.
Just so you know, some of the mail servers are flagging your e-mails as spam.. Not sure why though..
MalibuJack
Postby Evo4Mad » Sun Oct 01, 2006 5:40 pm
yeah I already know, its because I used the IIS smtp server to send them, I think its a normal way for spammers to send email. I'll use an automated outlook script next time.
Postby evoralph » Sun Oct 01, 2006 10:41 pm
LC1 datalogging working perfect. Great job :).
evoralph
Postby dryad » Tue Oct 03, 2006 4:24 am
I'll have some TXS logs to you later today.
dryad
Postby nvr2fast » Tue Oct 03, 2006 11:00 am
Good news that Wideband support is coming together.
However, which wideband unit has better support?
Or which would work better? I've looked and they all seem to do similarly (ie. bosch sensor and similar).
I've never tried these wideband units, could somone suggest which one might work best in combination with the software?
nvr2fast
LC1 Logging works. Question on Speed.
Postby NoQuarter » Wed Oct 04, 2006 4:47 am
My LC-1 seems to be logging just fine!
Has the problem with speed been discussed and I missed it? The speed field showed me doing about 100mph when I went no faster than about 80. I have the stock wheels and tires so no changes there.
NoQuarter
Postby rwunsche » Wed Oct 04, 2006 5:24 am
KPH, not MPH.
rwunsche
Postby NoQuarter » Wed Oct 04, 2006 8:23 am
rwunsche wrote:KPH, not MPH.
I kinda thought that but i didn't do the arithemetic to be sure. The units say MPH.
NoQuarter
Postby rwunsche » Wed Oct 04, 2006 9:21 am
Yeah, he put the wrong label (or the wrong calculation, depending on how you look at it). You can edit the data.xml file to fix it however you prefer. The resolution isn't that great (~4mph increments, I think).
rwunsche
Postby Evo4Mad » Wed Oct 04, 2006 3:42 pm
Yeah the factory speed sensor & ecu didn't require require high resolution speed. Bugger huh, hopefully the AYC or ABS ecu's have a better resolution.
Postby benji » Thu Oct 05, 2006 6:34 pm
First of all thanks to what seems to be a great product. I say seem because I am having some trouble.
I am using the OpenPort 1.3m and it does connect to the car, however, when I start the datalogger, I get the following message:
"Error: FTDI Read Timeout"
"Info: Datalogger ended"
Any ideas?
benji
Postby Evo4Mad » Thu Oct 05, 2006 8:57 pm
benji some vehicles need pins 1 and 4 on the obdII plug to joined. for mine I just use a paperclip in the back of the plug.
Postby benji » Thu Oct 05, 2006 9:03 pm
Evo4Mad wrote:benji some vehicles need pins 1 and 4 on the obdII plug to joined. for mine I just use a paperclip in the back of the plug.
on the back of the plug of the OBDII port in the car or the back of the connector of the cable? Also, which are pin 1 and 4?
benji
Postby dryad » Fri Oct 06, 2006 4:32 am
Evo4mad,
I have a TXS log but it didn't generate any values from the wideband. Is this normal? I'm sending you the log here in a few minutes. Sorry it took longer than expected.
dryad
Load Calc feature?
Postby NoQuarter » Sat Oct 07, 2006 7:11 pm
Just looking to see if there is new information on when the Load Calc may be available?
EDIT: According to the Email I just got, it's in the last release! :D
NoQuarter
