EvoScan Gauge Templates
Postby BarryC. » Mon Apr 02, 2007 1:37 am
sikrsix wrote:Why doesnt the "barryC" layout work for me? I have done 3 other gauge zip file transfers and they work... but The nicest one I found (barryc's) doesnt work????????? Any input would be great.. THANKS
sent you a pm :wink:
BarryC.
Postby kreionic » Mon Apr 02, 2007 1:18 pm
I have been using barrys layout also. I am trying to change the load to read higher. Its not working for me though. When I try and move the scales up to 300 load it saves and works fine but when I set the data to it it goes up to 500? I suck at these gauges. I a abotu to give up with them and keep my fingers crossed that some people post up some good layouts.
kreionic
Postby TouringBubble » Mon Apr 02, 2007 3:20 pm
I've had a few people ask about these, so I'll go ahead and post them ...
Download Left Side
This file includes:
Speedometer (MPH + KM/h)
3-stage Speed Warning Indicator (80, 100, 110)
Tachometer
2-stage STi-styled Shift Light (6k, 7k)
AFR Display (Not Tested)
AFR Indicator Lights (Not Tested)
Download Right Side
This file includes:
Coolant Temp
TPS
TPS Indicator (95% - 100%)
Boost (Not Tested)
Knock Count
Knock Indicator
Load
Timing Advance
Octane
Here is a layout file with many values already assigned.
Enjoy.
TouringBubble
Postby BarryC. » Sun Jul 08, 2007 12:39 pm
new one from me as usual if ya want it pm me, :wink:
BarryC.
Postby BarryC. » Tue Jul 10, 2007 11:12 am
evoscan files :wink:
Evo VRS.xml
(17.82 KiB) Downloaded 1423 times
BarryC.
Postby BarryC. » Tue Oct 09, 2007 2:18 am
BarryC.
Postby BarryC. » Tue Oct 09, 2007 7:44 am
template.zip
(7.87 KiB) Downloaded 1259 times
layout.zip
(6.12 KiB) Downloaded 1287 times
BarryC.
Postby Kane » Wed Oct 10, 2007 11:02 am
Will any of these gauges work with v. 1.0?
Kane
missing gauges
Postby roberttonge » Thu Oct 11, 2007 5:55 am
Please advise how i can receive the missing gauges, the layout is thee but the gauges are all missing please help.
roberttonge
Postby BarryC. » Fri Oct 12, 2007 7:03 am
should work with all versions :wink:
you have to be registered on here in order to download them
BarryC.
Postby BarryC. » Mon Nov 26, 2007 10:58 am
and the latest
template.zip
(7.87 KiB) Downloaded 1298 times
BarryC.
Postby BarryC. » Mon Nov 26, 2007 10:59 am
:wink:
layout.zip
(6.12 KiB) Downloaded 1327 times
BarryC.
Postby cossie1 » Mon Nov 26, 2007 3:25 pm
Barry that new layout looks sweet, but it won't load up for me :evil:
cossie1
Postby evo8 » Thu Nov 29, 2007 2:52 am
Barry - the last one you posted (Mon Nov 26, 2007 10:58 am) is not in the template and the layout file. Can you please post - looks very nice.
evo8
Re:
Postby RossRyan » Thu Sep 26, 2013 8:59 am
C6ect.ect wrote:Is there any possiblity in the future to have an output signal which runs an LED wired to a connector and have it set up similar to the widget so that whenever knock activity occurs, the LED lights up?
I really enjoy the widget right now while logging, whenever I log I have knock monitored, but a plug in
led light would be cool too
Yes now we use output signal which runs an LED wired to a connector. Things have changed lot in last few years and it has become more simpler now
RossRyan
