EVOSCAN v2.5 and Subaru Impreza Turbo MY00 (EU)
Postby Krzysiek_WAWA » Thu Aug 21, 2008 10:36 pm
Hello
I'v got a problem with capture logs. Default configuration capture frame every 3s, its to to long. Is anybody know what change in configuration to capture all logs with all frames
Regards Cris
EvoScanDataLog_2008.08.22_06.43.05.csv
Subaru Impreza GT (Europe Version)
(194.2 KiB) Downloaded 815 times
Krzysiek_WAWA
Postby NSFW » Thu Aug 28, 2008 12:00 pm
It is because you are logging so many parameters. The more parameters you log, the longer it takes to get each row.
You should log only what you need.
NSFW
Postby Krzysiek_WAWA » Sun Aug 31, 2008 10:02 am
Ok. Thanks.
Krzysiek_WAWA
