using enginuity i can edit a C521 rom, but with ecuflash it can only see two uneditable ignition maps
if i write to the ecu using that rom will it write the whole rom? or will it just attempt to modify the two imaginary ign maps? or is this the way its always been done and i need to try a little harder to get in the loop?
thanks
