HELP! I killed my ECU
Postby jblaze » Sun Aug 27, 2006 3:07 pm
I lost ignition power mid way through a re-flash. Now I am locked out of the ECU and I can't reconnect ECU flash
Everytime I turn the ignition on, it goes into test mode (the engine fans cycle) even though I have disconnected all the jumpers. I havn't tried starting the car yet.
Is their anyway (besides buying a new ECU) to fix this?
jblaze
Postby C6ect.ect » Sun Aug 27, 2006 5:59 pm
Reset Battery to car for 30 min
Try again
C6ect.ect
Postby jblaze » Sun Aug 27, 2006 7:57 pm
Tried that still no luck. The fans no longer cycle in test mode
jblaze
Postby jblaze » Sun Aug 27, 2006 8:48 pm
Take that back.....
Fans do cycle in test mode (and not normal mode) but still can't connect to ECU
jblaze
Postby calvinc » Mon Aug 28, 2006 10:24 pm
what part of the rom image were you modifying? if it was the actual operation code of the ecu then you may be in trouble, if it was just maps then things should still be as normal - maps a little screwy but you can always fix that.
Postby jblaze » Tue Aug 29, 2006 3:29 pm
I was half way through reflashing some of the fuel maps that I modified.
I tried yesterday to reflash again but I couldn't get ECU flash to connect.
jblaze
Postby 05GarnetLGT » Tue Aug 29, 2006 8:02 pm
this scares me, makes me want to not flash my car
05GarnetLGT
Postby UKspec » Thu Aug 31, 2006 1:49 pm
- Check your wires.
- Try to reflash with an other map. (previous bin or stock map)
UKspec
Postby jblaze » Thu Aug 31, 2006 3:38 pm
Wiring is all ok.
It doesn't matter what map I used, i can't get ECUflash to connect to the ECU
jblaze
Postby Tuned by LIM » Fri Sep 01, 2006 10:52 am
if you lost ignition power in reflash progress may damage ECU reflash mode and you can not go to reflash mode anymore.
I think you should ask cboles for this problem.
Tuned by LIM
Re: HELP! I killed my ECU
Postby Jon [in CT] » Fri Sep 01, 2006 3:05 pm
jblaze wrote:I lost ignition power mid way through a re-flash.
Can you describe/explain how this happened?
Postby cboles » Fri Sep 01, 2006 3:27 pm
what model/year car do you have? how did the power get cut during the reflash?
Postby Hobbes » Fri Sep 01, 2006 4:21 pm
Freudian slip
lost ignition power verses lost power
ignition power = controlled by the key
lost power = dead battery, blown fuse,
Top Flash killers
Weak battery (due to ignition on too long)
Kick or knock cable off during flash
Lap top dies during flash
Turbo timer confusion
Depending on where in the read write step the cut happened.
Hobbes
Postby cboles » Sun Sep 03, 2006 1:24 pm
cboles wrote:what model/year car do you have?
Postby jblaze » Sun Sep 03, 2006 3:38 pm
I have a 2003 WRX (ADM).
I lost power via an ignition key off.
When I started the flash process I thought ECUflash didn't make a successful connection to the ECU as it doesn't connect every time (the whole press "OK" then QUICKLY turn your ignition on problem). Then just as I keyed off it connected and started the flash process.
jblaze
