I'm a noob to flashing, so I've read every FAQ and all of the troubleshooting I could find here and still have been unable to connect to the stock ECU on my 04 WRX MT Wagon with either Ecuflash or ecuExplorer.
Any thoughts / suggestions on what I'm doing wrong?
Thanks for your help,
Kyle "BlackHole"
Hardware/Software:
-Tactrix OpenPort 1.2 cable
-Win2k fully updated on older IBM T21 laptop
-latest versions of EcuFlash and ecuExplorer installed
-flash jumper installed
-both under dash and pass footwell diagnostic connectors connected
Tried:
-followed all published instructions on how to flash (here, enginuity, etc.)
-confirmed that car was behaving as expected of diag. mode
-confirmed that Windows Device Manager sees OpenPort cable and is installed correctly
-un & re-installed EcuFlash and ecuExplorer
-unsuccessfully tried w/o the flash jumper installed
-EcuFlash popup error message says to check log. But no log can be found.
-eliminated one error message by moving FTD2XX.dll to winnt/system32 folder
-different ignition key timings versus EcuFlash "OK" button
Notes:
-Device Manager says the OpenPort cable is on COM5, but EcuFlash will only attempt to connect on COM4. All other ports yield error messages.
EcuFlash display:
[00:30:41.317] Version 1.28.716
[00:30:41.337] 8 memory models read.
[00:30:41.948] 71 ROM metadata models read.
[00:30:41.948] checksum module "subarudbw" loaded.
[00:30:41.948] flashing tool "wrx02" loaded.
[00:30:41.948] flashing tool "wrx04" loaded.
[00:30:41.948] flashing tool "sti04" loaded.
[00:30:41.958] flashing tool "sti05" loaded.
[00:30:41.958] flashing tool "mitsukernel" loaded.
[00:30:41.958] flashing tool "mitsukernelocp" loaded.
[00:30:41.958] flashing tool "mitsubootloader" loaded.
[00:30:48.668] ssm2_init
[00:30:48.878] ssm2_init
[00:30:49.088] ssm2_init
[00:30:49.299] ssm2_init
[00:30:49.509] ssm2_init
[00:30:49.719] ssm2_init
[00:30:49.930] ssm2_init
[00:30:50.140] ssm2_init
[00:30:50.350] ssm2_init
[00:30:50.560] ssm2_init
[00:30:50.921] kernel get version
[00:30:51.432] validating denso kernel ram area addr: 020000 len: 0008
