Barometric compensation adjusted to climate
I do know the ECU monitors the barometric psi and will adjust timing in respect, my question is how would I fine tune these values to be a little more specific to my driving environment (sea level).
Since Evo ECU is known to pull timing for other reasons than knock activity, I was pondering on perhaps the factory baro settings are way too broad to accomidate different climates which sounds likely part of reason for inconsistant timing.
My car is driven at sea level 100% of the time so would tuning the barometer compensation for this provide any benifits? Or is it totally different?
If so, how
If so, how
