wasent able to get a rom dunp from an 05 LGT using ecuflash
Postby jak » Sat Jul 08, 2006 6:19 pm
I plugged in the D check conector & did what the programm asked me to do & it seemed to upload but then had an error message at the end saying I needed to look at the log which I couldent really find
I probably did something rong :-) any help at all would be great :-)
thanks
JAK
jak
Postby Tea cups » Sat Jul 08, 2006 7:27 pm
Half the time people have problems because they turn on their ignition on too early. You should leave your ignition off until you are prompted to turn it on by Ecuflash and then immediately turn it on and hit OK immediately.
Tea cups
Postby jak » Sun Jul 09, 2006 7:41 am
Ill try some more with it
at first I did have the key on rather then waiting but then I did try to do it as prompted
this was my first time with it & I probably just need to screw around with it a bit more to get comfortable with it
thanks for your help
take care
JAK
jak
