Open/Close Loop Throttle ??? for JDM ECU's
Postby west_minist » Fri Jun 23, 2006 8:53 pm
<ecu_struct id="A4SD900A" type="JDM WRX 01/02 - af471 7086">
<map name="Open/Closed Loop Fuel Throttle" type="2" active="1" help="" level="0">
<rows count="16" offset="#28F08" power="2" inc_value="2048" func_2inc="[value]" func_inc2="[value]" func_2val="[value]/5.12" func_val2="[value]*5.12" signed="False" format="%.0f" caption="RPM" desc="Engine RPM"/>
<data offset="#28F0C" power="1" func_2val="[value]/1.699843750000001" func_val2="[value]*1.699843750000001" signed="False" format="%.2f" caption="%" desc="Throttle Angle" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<ecu_struct id="A4TJ121C" type="JDM Twin Scroll STI RAC 06 - al380 2270">
<map name="Open/Closed Loop Fuel Throttle ??? - 289FC" type="2" active="1" help="" level="0">
<rows count="16" offset="#28A22" power="2" inc_value="2048" func_2inc="[value]" func_inc2="[value]" func_2val="[value]/5.12" func_val2="[value]*5.12" signed="False" format="%.0f" caption="RPM" desc="Engine RPM"/>
<data offset="#28A26" power="1" func_2val="[value]/1.699843750000001" func_val2="[value]*1.699843750000001" signed="False" format="%.2f" caption="%" desc="Throttle Angle" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<ecu_struct id="A4TE002B" type="JDM Twin Scroll STI 03 - ah581 5122">
<rows count="16" offset="#289FC" power="2" inc_value="2048" func_2inc="[value]" func_inc2="[value]" func_2val="[value]/5.12" func_val2="[value]*5.12" signed="False" format="%.0f" caption="RPM" desc="Engine RPM"/>
<data offset="#28A00" power="1" func_2val="[value]/1.699843750000001" func_val2="[value]*1.699843750000001" signed="False" format="%.2f" caption="%" desc="Throttle Angle" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
