ECUFLASH: Version 1.26 released
Postby west_minist » Thu May 11, 2006 10:07 am
Hello!
I cannot open save roms with this software.
Is there a reason for that?
Re: ECUFLASH: Version 1.26 released
Postby ev8siv3 » Thu May 11, 2006 11:09 am
west_minist wrote:Hello!
Do you have an XML definitions file for it? Please post your ROM, year make and model and whichever Def file you are using.
ev8siv3
Postby west_minist » Thu May 11, 2006 11:24 am
I can open the roms and the definitions come down, but gets an error.
ecuflash 1.26 error.png (40.88 KiB) Viewed 7638 times
Postby ev8siv3 » Thu May 11, 2006 11:59 am
west_minist wrote:I can open the roms and the definitions come down, but gets an error.
Post your ROM and I'll make a DEF for it. You are using A4TE002B.
ev8siv3
Postby west_minist » Thu May 11, 2006 12:17 pm
That was the rom I download from off openecu.
http://forums.openecu.org/viewtopic.php?t=81
JDM Twin Scroll STi - AH581-5122.hex
(192 KiB) Downloaded 731 times
Postby RallyCam » Thu May 11, 2006 12:54 pm
It also appears not to work with the Evo 7 files posted in the Evo forum.
http://forums.openecu.org/viewtopic.php?t=277 (EM9986)
It did however open the Evo 8 file I tried.
RallyCam
Postby ev8siv3 » Thu May 11, 2006 1:12 pm
west_minist wrote:That was the rom I download from off openecu.
Here you go. Use XMLWrite on any ROM that doesn't have a valid XML file.
A4TE002B.zip
(8.77 KiB) Downloaded 444 times
ev8siv3
Postby Spiider » Thu May 11, 2006 1:25 pm
There is an error with XMLWrite v5 and the a4te002b "desired boost auto", rpm row settings.
Should start at "2a9a9" and power = 2 byte, right now it says "2a9be" and power = 1 byte.
I just edited manually edited my xml to work correctly.
Postby Garage Tuning » Thu May 11, 2006 4:46 pm
I get the same error no matter what using a map that I have flashed and run on cars before.
Garage Tuning
Postby Garage Tuning » Thu May 11, 2006 4:49 pm
Tried lots of roms now. Same error on any checkbox.
Garage Tuning
Postby Garage Tuning » Thu May 11, 2006 4:53 pm
Wierd. Loaded the rom from my car. I've never been able to open it. It worked, but Wastegate Duty Compensation still gives the error.
Garage Tuning
