4g63 ´91 non Turbo with EV0 8 ECU
Postby musicmze » Wed Feb 22, 2012 2:58 am
Hello,
i think, i´m not the first with this Question, but i searched the web and didn´t find an answer.
I´ve a Lancer 91 with swapped 4g63 Block and 4g67 Head (15Bar Compression) 609MAF and 275 DSM Injectors. Now i swapped to the Lancer CS0 2005 (=EVO8 ECU) and it works with an EVO 8 Rom - but not good, and i´m a beginner in ecu tuning...
Does anyone has an Rom + XML for this non Turbo Setup, or such a similar Rom which could work?
I have read the Lancer CS0 4g63 Rom, but no XML - i think, this could work. Does anyone has an idea?
Best regards and thanks from Germany
Martin
PS: sorry for my english...
Lancer2005nonTurbo4g63.hex
(256 KiB) Downloaded 897 times
musicmze
Re: 4g63 ´91 non Turbo with EV0 8 ECU
Postby GMS » Wed Feb 22, 2012 9:43 am
GMS
Postby musicmze » Wed Feb 22, 2012 12:37 pm
Hi,
thanks a lot for the answer! Tomorrow i´ll try the xml.
best regards
Martin
musicmze
Postby musicmze » Wed Feb 22, 2012 12:43 pm
Now i copied the xml into "Lancer".
When i open the *.bin, it works, but it doesn´t show me the maps... Or isn´t it such a xml?
thanks, Martin
musicmze
Postby GMS » Wed Feb 22, 2012 11:07 pm
I have checked up, xml is correct.
GMS
Postby musicmze » Thu Feb 23, 2012 1:14 am
Which ECUflash Version do you use?
Is the folder correct, where the xml is in?
best regards Martin
musicmze
Postby musicmze » Fri Feb 24, 2012 1:02 am
Hello,
yesterday i tested the rom and ecuflash reads it.
But my car won´t do anything... Now i have to test a little bit.
Does anyone know about the latency times for 275 1g dsm injectors and a table for the 609 maf in this setup? I think, this could be the matter...
Sorry for my questions, but it´s not easy without experience in this. For the worst case - i have my old e33 GTI ECU, and this works fine :-D
With this rom (attachement - evo8 for 4g63 non turbo with big injectors and e85... not perfect for my car) the car works sometimes, but only to 3500 rpm - then it plops and bangs in the exhaust and intake.
thanks a lot, Martin
TephraMOD-96530706-v7.xml
(75.44 KiB) Downloaded 915 times
2.12.10.hex
(256 KiB) Downloaded 881 times
musicmze
