Can't write to MY02 Impreza
Postby edcmat-l1 » Thu Dec 29, 2011 9:21 am
I read the ROM just fine. I can test write to it and that seems to work fine. When I try to write to it, I get a "Program voltage is 4.32 volts" "Program voltage is out of range!" But I don't think it is. I have a charger on the car. I have not checked anything with a volt meter or scope yet, but it cranks over and runs fine. Just won't write.
edcmat-l1
Re: Can't write to MY02 Impreza
Postby edcmat-l1 » Thu Dec 29, 2011 4:56 pm
Here's the log text.................
[12:33:50.984] reading kernel comm buffer size
[12:33:51.000] comm buffer size set to 512
[12:33:51.000] reading kernel flash buffer size
[12:33:51.000] flash buffer size set to 4096
[12:33:51.000] -- flashing image to ECU memory --
[12:33:51.406] -- comparing ECU flash memory pages to image file --
[12:33:51.406] seg start len ecu CRC32 img CRC32 same?
[12:33:51.734] FB01 00000000 00004000 19358932 19358932 YES
[12:33:52.046] FB02 00004000 00004000 7FEB9078 7FEB9078 YES
[12:33:52.375] FB03 00008000 00004000 C949D99B C949D99B YES
[12:33:52.687] FB04 0000C000 00004000 A7B2322D A7B2322D YES
[12:33:53.015] FB05 00010000 00004000 F6AE956A F6AE956A YES
[12:33:53.328] FB06 00014000 00004000 92ED48B7 92ED48B7 YES
[12:33:53.656] FB07 00018000 00004000 56326D4C 56326D4C YES
[12:33:53.968] FB08 0001C000 00004000 1675D4F1 1675D4F1 YES
[12:33:54.296] FB09 00028000 00004000 FAD7363A 24A00B23 NO
[12:33:54.625] FB10 0002C000 00004000 3A85CBEA 3A85CBEA YES
[12:33:54.937] reading ecu programming voltage
[12:33:54.937] programming voltage is 4.32 volts
[12:33:54.937] programming voltage is out of range!
[12:33:54.937] interface close
[12:33:54.953] interface close
I did some experimenting, and it appears I can flash the original file, just not one that's modified. I tried several variations, and none would write except the original.
edcmat-l1
Postby radsdau » Mon Jan 02, 2012 3:35 pm
Most likely a flash jumper block broken or missing. On some models this 'pipes through' the 12V flash voltage from the programming cable.
Also if it's an OP1.x cable I've seen a few of those fail. There's a small 12V regulator in there; check if that's working ok.
