Using interface test ftE2FPQR ?????? 03 WRX
Postby Slatts » Wed Jul 13, 2011 4:32 pm
03 WRX Windows Vista 7, Taxtrics 2.0 cable.
I flashed 2 days ago, tried flashing tonight, and it wont work. The interface shows "Using interface test ftE2FPQR". ANyone have a clue how to change that to Openport 2.0?
Flashplug is in, test connectors are good (fans cycle etc.) Seems to be an interface problem, but I cant get it to see the cable. Logging is good.
[20:21:44.979] EcuFlash Version 1.42.2595
[20:21:44.979] OS Version Windows Vista
[20:21:44.979] Qt Version 4.5.0
[20:21:44.995] 56 memory models read.
[20:21:44.995] scanning for metadata models in C:/OpenECU/EcuFlash/rommetadata
[20:21:45.385] 355 ROM metadata models scanned.
[20:21:45.385] checksum module "subarudbw" loaded.
[20:21:45.385] checksum module "mitsucan" loaded.
[20:21:45.385] flashing tool "wrx02" loaded.
[20:21:45.385] flashing tool "wrx04" loaded.
[20:21:45.385] flashing tool "sti04" loaded.
[20:21:45.385] flashing tool "sti05" loaded.
[20:21:45.385] flashing tool "mitsukernel" loaded.
[20:21:45.385] flashing tool "mitsukernelocp" loaded.
[20:21:45.385] flashing tool "mitsubootloader" loaded.
[20:21:45.385] flashing tool "shbootmode" loaded.
[20:21:45.385] flashing tool "shaudmode" loaded.
[20:21:45.385] flashing tool "subarucan" loaded.
[20:21:45.385] flashing tool "mitsucan" loaded.
[20:22:39.599] Using interface test ftE2FPQR
[20:22:44.925] denso02_bootloader_cmd_start
[20:22:44.941] readback mismatch
[20:22:45.861] denso02_bootloader_cmd_start
[20:22:45.877] readback mismatch
[20:22:46.797] denso02_bootloader_cmd_start
[20:22:46.797] readback mismatch
[20:22:47.733] denso02_bootloader_cmd_start
[20:22:47.764] readback mismatch
[20:22:48.685] denso02_bootloader_cmd_start
[20:22:48.716] readback mismatch
[20:22:48.841] kernel get version
[20:22:48.841] readback mismatch
[20:22:48.950] interface close
[20:22:48.966] interface close
Thanks for any help.
Slatts
Re: Using interface test ftE2FPQR ?????? 03 WRX
Postby Slatts » Wed Jul 13, 2011 5:57 pm
OK, the problem was I had the AEM wideband plugged into another port and it was causing a conflict with the Openport 2.0 USB port.
Slatts
