solved problem flashing ecu and reading errors
Ok so i have a subaru legacy rev d 2002 Rsk, it suffers from some mad det and i was playing with maps today.
Any ways i reflashed a few times with different maps did some logging and then on one of the last flashes i did today i got ....
02_densobootloader
02_densobootloader
02_densobootloader
02_densobootloader
02_densobootloader
kernel get interface.....
now this happened weirdly after a failed flash, i was upset and confused ecuflash said the software didnt flash and my ecu would be toast and car wouldnt start etc etc ....
So i tried to flash again and it wrote but didnt complete.
Any ways after researching the error and trying to figure it out i tried re seating green connectors, tried everything, sadly my previous tuner didnt have the four pin bridge cable and used some wire paper clips to bridge the connector..... now ha i said to myself those cant be very good i removed them and put my tactrix original four pin jumper, tried to read the ecu and it worked, tried to flash and it worked, if any one has this error and is battling check the four pin connector its worth it and dont use a paper clip jumper for the four wires, use the original tactrix four pin connector.
It will save you time and money and headaches always make sure that the pins arent bent and are clean .
Now i have a question to ask.
How do i flash my original Hex file onto my ecu if ecu flash doesnt have definition files for the rom file, how do i make it open and flash it onto my ecu as i am testing for det now that winter is here in africa would like to assess if the change in temps will make it less prone and if i can counter act this using methanol etc etc.
Please help cheers
Adam
02_densobootloader
02_densobootloader
02_densobootloader
02_densobootloader
02_densobootloader
Please help cheers
Adam
