So i was reflashing an MY06 WRX and it failed. No car wont start and also can reflash again. Even with the green connectors pluged, check engine light wont flash.
Heres the ecuflash log:
[19:57:09.667] Using interface OpenPort 1.3 Universal TX26P4u0842cb4d57c84896114dfea89370c8d3c0ea5a48c
[19:57:13.089] kernel get version
[19:57:13.464] SSM2 init
[19:57:13.714] SSM2 ECU ID is 4D FFFFFFA2 58 40 06
[19:57:13.808] Requesting Seed...
[19:57:13.855] Sending Key...
[19:57:14.511] writing kernel area addr: FFFF3000 len: 0D00
[19:57:14.511] SSM2 write kernel ram block addr: FFFF3000 len: 0080
[19:57:14.605] SSM2 write kernel ram block addr: FFFF3080 len: 0080
[19:57:14.714] SSM2 write kernel ram block addr: FFFF3100 len: 0080
[19:57:14.808] SSM2 write kernel ram block addr: FFFF3180 len: 0080
[19:57:14.917] SSM2 write kernel ram block addr: FFFF3200 len: 0080
[19:57:15.011] SSM2 write kernel ram block addr: FFFF3280 len: 0080
[19:57:15.121] SSM2 write kernel ram block addr: FFFF3300 len: 0080
[19:57:15.214] SSM2 write kernel ram block addr: FFFF3380 len: 0080
[19:57:15.324] SSM2 write kernel ram block addr: FFFF3400 len: 0080
[19:57:15.417] SSM2 write kernel ram block addr: FFFF3480 len: 0080
[19:57:15.527] SSM2 write kernel ram block addr: FFFF3500 len: 0080
[19:57:15.621] SSM2 write kernel ram block addr: FFFF3580 len: 0080
[19:57:15.730] SSM2 write kernel ram block addr: FFFF3600 len: 0080
[19:57:15.824] SSM2 write kernel ram block addr: FFFF3680 len: 0080
[19:57:15.933] SSM2 write kernel ram block addr: FFFF3700 len: 0080
[19:57:16.042] SSM2 write kernel ram block addr: FFFF3780 len: 0080
[19:57:16.136] SSM2 write kernel ram block addr: FFFF3800 len: 0080
[19:57:16.246] SSM2 write kernel ram block addr: FFFF3880 len: 0080
[19:57:16.355] SSM2 write kernel ram block addr: FFFF3900 len: 0080
[19:57:16.449] SSM2 write kernel ram block addr: FFFF3980 len: 0080
[19:57:16.558] SSM2 write kernel ram block addr: FFFF3A00 len: 0080
[19:57:16.667] SSM2 write kernel ram block addr: FFFF3A80 len: 0080
[19:57:16.761] SSM2 write kernel ram block addr: FFFF3B00 len: 0080
[19:57:16.871] SSM2 write kernel ram block addr: FFFF3B80 len: 0080
[19:57:16.964] SSM2 write kernel ram block addr: FFFF3C00 len: 0080
[19:57:17.074] SSM2 write kernel ram block addr: FFFF3C80 len: 0080
[19:57:17.621] kernel get version
[19:57:17.621] kernel version is : OpenECU Subaru SH7058 OCP Kernel V1.06
[19:57:17.621] reading kernel comm buffer size
[19:57:17.636] comm buffer size set to 512
[19:57:17.636] reading kernel flash buffer size
[19:57:17.652] flash buffer size set to 4096
[19:57:17.652] -- flashing image to ECU memory --
[19:57:18.058] -- comparing ECU flash memory pages to image file --
[19:57:18.058] seg start len ecu CRC32 img CRC32 same?
[19:57:18.074] FB01 00000000 00001000 74F39041 74F39041 YES
[19:57:18.105] FB02 00001000 00001000 AF542FCA AF542FCA YES
[19:57:18.121] FB03 00002000 00001000 9FE7CFE3 9FE7CFE3 YES
[19:57:18.152] FB04 00003000 00001000 C1B48B79 C1B48B79 YES
[19:57:18.167] FB05 00004000 00001000 6A48356A 6A48356A YES
[19:57:18.183] FB06 00005000 00001000 930AB4C2 930AB4C2 YES
[19:57:18.214] FB07 00006000 00001000 8CB9629E 8CB9629E YES
[19:57:18.230] FB08 00007000 00001000 1BBF3797 1BBF3797 YES
[19:57:18.496] FB09 00008000 00018000 95EB2B1A 95EB2B1A YES
[19:57:18.824] FB10 00020000 00020000 D2CB5FA2 D2CB5FA2 YES
[19:57:19.167] FB11 00040000 00020000 C4E689B9 C4E689B9 YES
[19:57:19.496] FB12 00060000 00020000 F418A2BA F418A2BA YES
[19:57:19.839] FB13 00080000 00020000 6AB6BB60 6AB6BB60 YES
[19:57:20.167] FB14 000A0000 00020000 CF380FC5 CF380FC5 YES
[19:57:20.511] FB15 000C0000 00020000 3BC74621 B25AFE57 NO
[19:57:20.855] FB16 000E0000 00020000 B90D13B8 C4644600 NO
[19:57:20.855] kernel flash enable
[19:57:20.871] kernel blank flash page: addr: 000E0000
[19:57:21.058] erased in 1 pulse(s)
[19:57:21.058] kernel write flash buffer addr: 000FF000 len: 00000200
[19:57:21.152] kernel write flash buffer addr: 000FF200 len: 00000200
[19:57:21.246] kernel write flash buffer addr: 000FF400 len: 00000200
[19:57:21.339] kernel write flash buffer addr: 000FF600 len: 00000200
[19:57:21.433] kernel write flash buffer addr: 000FF800 len: 00000200
[19:57:21.527] kernel write flash buffer addr: 000FFA00 len: 00000200
[19:57:21.621] kernel write flash buffer addr: 000FFC00 len: 00000200
[19:57:21.714] kernel write flash buffer addr: 000FFE00 len: 00000200
[19:57:21.808] kernel commit flash addr: 000FF000 len: 00001000 crc32 207822c6
[19:57:21.839] written in 1 pulse(s)
[19:57:21.839] kernel blank flash page: addr: 000C0000
[19:57:23.167] erased in 1 pulse(s)
[19:57:23.167] kernel write flash buffer addr: 000C0000 len: 00000200
[19:57:23.261] readback mismatch
[19:57:23.261] reading kernel comm stats
[19:57:23.277] readback mismatch
[19:57:23.277] kernel write flash buffer addr: 000C0000 len: 00000200
[19:57:23.371] readback mismatch
[19:57:23.371] reading kernel comm stats
[19:57:23.371] kernel write flash buffer addr: 000C0000 len: 00000200
[19:57:23.464] readback mismatch
[19:57:23.464] reading kernel comm stats
[19:57:23.464] kernel write flash buffer addr: 000C0000 len: 00000200
[19:57:23.558] readback mismatch
[19:57:23.558] reading kernel comm stats
[19:57:23.558] kernel write flash buffer addr: 000C0000 len: 00000200
[19:57:23.652] readback mismatch
[19:57:23.652] reading kernel comm stats
[19:57:23.652] kernel write flash buffer addr: 000C0000 len: 00000200
[19:57:23.730] readback mismatch
[19:57:23.730] reading kernel comm stats
[19:57:23.730] failure in flashing block
[19:57:23.730] kernel flash disable
[19:57:23.746] readback mismatch
[19:57:23.746] interface close
[19:57:23.761] interface close
Please tell me it's not bricked!! And it's an easy solution.
Thanks guys.
