6.5 TME 7203FA bricked?
27370001 (96 tables) inheriting evo5base (79 tables)
[23:54:29.876] 131072 byte image read.
[23:54:36.506] J2534 API Version: 04.04
[23:54:36.506] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[23:54:36.506] Device Firmware Version: 1.11.3157
[23:54:39.503] sending init sequence 2
[23:54:39.510] got 0x13 response instead of 0x11
[23:54:39.510] sending init sequence 3
[23:54:39.866] entering bootloader
[23:54:39.868] sending kernel size (2027)
[23:54:39.878] sending kernel load address (0x0000F000)
[23:54:39.888] uploading kernel
[23:54:40.216] verifying kernel checksum response
[23:54:40.220] kernel valid
[23:54:40.420] kernel get version
[23:54:40.433] kernel version is : OpenEcu Mitsubishi H8/539FA Kernel V1.06
[23:54:40.433] reading kernel comm buffer size
[23:54:40.448] comm buffer size set to 256
[23:54:40.448] reading kernel flash buffer size
[23:54:40.456] flash buffer size set to 1024
[23:54:40.475] -- flashing image to ECU memory --
[23:54:40.876] -- comparing ECU flash memory pages to image file --
[23:54:40.876] seg start len ecu CRC32 img CRC32 same?
[23:54:40.896] EB0 00010000 00000400 A5BFA22E CB1D61AF NO
[23:54:40.918] EB1 00010400 00000400 B83AFFF4 B83AFFF4 YES
[23:54:40.939] EB2 00010800 00000400 6714F05F 45F86304 NO
[23:54:40.960] EB3 00010C00 00000400 9F238897 9F238897 YES
[23:54:41.300] EB4 00011000 00007000 9959BB12 1D5C5DE3 NO
[23:54:41.686] EB5 00018000 00008000 A7DEE559 754D7E8F NO
[23:54:42.072] EB6 00020000 00008000 70B97A2D F862C931 NO
[23:54:42.459] EB7 00028000 00008000 5D8FBB76 050F997D NO
[23:54:42.459] kernel flash enable
[23:54:42.467] kernel blank flash page: addr: 00028000
[23:54:42.535] erased in 2 pulse(s)
[23:54:42.535] kernel write flash buffer addr: 00028000 len: 00000100
[23:54:42.585] kernel write flash buffer addr: 00028100 len: 00000100
[23:54:42.634] kernel write flash buffer addr: 00028200 len: 00000100
[23:54:42.683] kernel write flash buffer addr: 00028300 len: 00000100
[23:54:42.732] kernel commit flash addr: 00028000 len: 00000400 crc32 221c50ba
[23:54:42.876] written in 24 pulse(s)
[23:55:12.854] kernel write flash buffer addr: 00017800 len: 00000100
[23:55:12.903] kernel write flash buffer addr: 00017900 len: 00000100
[23:55:12.952] kernel write flash buffer addr: 00017A00 len: 00000100
[23:55:13.001] kernel write flash buffer addr: 00017B00 len: 00000100
[23:55:13.051] kernel commit flash addr: 00017800 len: 00000400 crc32 89a59733
[23:55:13.199] written in 24 pulse(s)
[23:55:13.199] kernel write flash buffer addr: 00017C00 len: 00000100
[23:55:13.248] kernel write flash buffer addr: 00017D00 len: 00000100
[23:55:13.297] kernel write flash buffer addr: 00017E00 len: 00000100
[23:55:13.346] kernel write flash buffer addr: 00017F00 len: 00000100
[23:55:13.395] kernel commit flash addr: 00017C00 len: 00000400 crc32 ed5f73e1
[23:55:13.545] written in 24 pulse(s)
[23:55:13.545] kernel blank flash page: addr: 00010800
[23:55:13.571] erased in 3 pulse(s)
[23:55:13.571] kernel write flash buffer addr: 00010800 len: 00000100
[23:55:13.620] kernel write flash buffer addr: 00010900 len: 00000100
[23:55:13.669] kernel write flash buffer addr: 00010A00 len: 00000100
[23:55:13.718] kernel write flash buffer addr: 00010B00 len: 00000100
[23:55:13.767] kernel commit flash addr: 00010800 len: 00000400 crc32 45f86304
[23:55:13.994] written in 28 pulse(s)
[23:55:13.994] kernel blank flash page: addr: 00010000
[23:55:14.020] erased in 3 pulse(s)
[23:55:14.020] kernel write flash buffer addr: 00010000 len: 00000100
[23:55:14.069] kernel write flash buffer addr: 00010100 len: 00000100
[23:55:14.118] kernel write flash buffer addr: 00010200 len: 00000100
[23:55:14.167] kernel write flash buffer addr: 00010300 len: 00000100
[23:55:14.216] kernel commit flash addr: 00010000 len: 00000400 crc32 cb1d61af
[23:55:14.411] written in 28 pulse(s)
[23:55:14.411] kernel flash disable
[23:55:14.419] verifying result...
[23:55:14.419] -- comparing ECU flash memory pages to image file --
[23:55:14.419] seg start len ecu CRC32 img CRC32 same?
[23:55:14.440] EB0 00010000 00000400 9D699BEC CB1D61AF NO
[23:55:14.461] EB1 00010400 00000400 B83AFFF4 B83AFFF4 YES
[23:55:14.482] EB2 00010800 00000400 A69F52C1 45F86304 NO
[23:55:14.507] EB3 00010C00 00000400 9F238897 9F238897 YES
[23:55:14.846] EB4 00011000 00007000 0D85BBB2 1D5C5DE3 NO
[23:55:15.232] EB5 00018000 00008000 15C426D9 754D7E8F NO
[23:55:15.618] EB6 00020000 00008000 093FEC77 F862C931 NO
[23:55:16.004] EB7 00028000 00008000 59BBED0D 050F997D NO
[23:55:16.004] *** FLASH FAILURE ***
[23:55:16.005] interface close
Just tried to write Ceddy1.2 beta for E5-6 in 6.5TME 7203FA ECU, but flash failed. Ecuflash 1.42. I've changed <memmodel> 8539F to 8539FA, as it was necessary.
Are they bricked? Have you any ideas?
Thank you
Vlad
Thank you
Vlad
