Simulate function.
PostPosted: Tue May 02, 2006 4:24 pm
by msjo
I notice that the "Simulate" function that was present on earlier versions of EcuFlash is not present on the current versions. I assume this finctions gives you the ability to try a map in your ECU without flashing it first, which is an awesome addition. Is this function likely to return, or is it still present and I just can't find it?
PostPosted: Tue May 02, 2006 4:55 pm
by cboles
The function was for development purposes, and it is only for simulating an ECU for the purposes of reflashing. It is out of date (e.g. no longer works), so I removed it. It may make a return later, but it won't be useful for what you were hoping it would do.
PostPosted: Tue May 02, 2006 5:53 pm
by msjo
OK, No problems.
Thanks mate!!
Michael.
