Hello I have troubles with this error code if I tried to read out or write the ecu:
I have tried it several times to read out the ecu and then it worked, but whole time I got this error message. At the moment its not possible to write or read out the ecu.
Is the ecu blocked, or whats the problem?
sending init sequence 1 (0001)
J2534 error [ERR_TIMEOUT].
interface close
Use OpenPort2.0 Interface, tried 1.42. and 1.43 version.
No stock file on ECU, but file is crap.
