KS-Tech 73mm MegaMAF Scaling
Postby BakZamGai » Tue Aug 03, 2010 7:35 pm
Hi folks
Total noob at this Open Source thing but I've just fitted a KS-Tech 73mm MegaMAF on my car and I believe that I need to make some adjustments to the MAF Scaling.
Has anyone done this already and can provide me with some base numbers to try out?
Thanks!
Cheers
Dennis
BakZamGai
Re: KS-Tech 73mm MegaMAF Scaling
Postby mafia69 » Mon Sep 13, 2010 6:03 am
bump
mafia69
Postby 06rexwagon » Thu Sep 30, 2010 10:54 am
What year/model? The WRX and STI have a different # of voltage break points. I've tuned this intake on both, so let me know and I can get you set in the right direction.
06rexwagon
Postby mafia69 » Thu Sep 30, 2010 11:57 am
02 WRX 16-bit. Please help. Could you post a working scaling? I really need one that has been done with known base like stock injectors.. Thanks! :) I am totally lost my hope to tune this thing.. :(
mafia69
Postby 06rexwagon » Fri Oct 01, 2010 6:35 am
The 16 bit car that I tuned was on 1000cc injectors, so it may not be the greatest for your needs. I have tuned it on my 06 but I'm able to go over 300g/s. I have done 5 or 6 STi's with the same intake. Send me a PM with your email and I'll send the one from the 16 bit and you can use it to get you close. Have you tried the MAF scaling tool in RomRaider?
06rexwagon
