HELP!!! ECU flash unable to read Evo 6 ecu
Hi all, Ive been advised I can use my 1.3u cable to remove the boost cut on a 1999 evo 6, Ive used ecuflach 1.28 with ecu unlocker, that could not read my ecu. Then I tried 1.42 and that failed as well here is the results:
[16:32:04.119] EcuFlash Version 1.42.2595
[16:32:04.119] OS Version Windows Vista
[16:32:04.119] Qt Version 4.5.0
[16:32:04.134] 56 memory models read.
[16:32:04.134] scanning for metadata models in D:/Program Files/EcuFlash/rommetadata
[16:32:04.462] 343 ROM metadata models scanned.
[16:32:04.462] checksum module "subarudbw" loaded.
[16:32:04.462] checksum module "mitsucan" loaded.
[16:32:04.462] flashing tool "wrx02" loaded.
[16:32:04.462] flashing tool "wrx04" loaded.
[16:32:04.462] flashing tool "sti04" loaded.
[16:32:04.462] flashing tool "sti05" loaded.
[16:32:04.462] flashing tool "mitsukernel" loaded.
[16:32:04.462] flashing tool "mitsukernelocp" loaded.
[16:32:04.462] flashing tool "mitsubootloader" loaded.
[16:32:04.462] flashing tool "shbootmode" loaded.
[16:32:04.462] flashing tool "shaudmode" loaded.
[16:32:04.462] flashing tool "subarucan" loaded.
[16:32:04.462] flashing tool "mitsucan" loaded.
[16:32:10.119] Using interface OpenPort 1.3b Universal TX28QLKKdbcb74d53511dd6d2eceae9c4cfe29c5b3877fff
[16:32:14.556] sending init sequence 2
[16:32:14.556] got 0x13 response instead of 0x11
[16:32:14.556] sending init sequence 3
[16:32:14.947] entering bootloader
[16:32:14.947] sending kernel size (2029)
[16:32:14.962] sending kernel load address (0x0000F000)
[16:32:14.978] uploading kernel
[16:32:15.306] verifying kernel checksum response
[16:32:15.322] kernel valid
[16:32:15.525] kernel get version
[16:32:15.541] kernel version is : OpenEcu Mitsubishi H8/539F Kernel V1.06
[16:32:15.541] reading kernel comm buffer size
[16:32:15.541] comm buffer size set to 256
[16:32:15.541] reading kernel flash buffer size
[16:32:15.556] flash buffer size set to 1024
[16:32:15.587] interface close
What should I do to remove the boost cut??? any help would be fantastic!!!!
P.S im running windoes 7 32bit
