Trouble flashing 2006 Legacy GT
I keep getting the same error message when trying to do a test flash on my 2006 Legacy GT:
[20:57:14.899] EcuFlash Version 1.41.2483
[20:57:14.899] OS Version Windows Vista
[20:57:14.899] Qt Version 4.4.0
[20:57:14.911] 26 memory models read.
[20:57:14.912] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[20:57:15.169] 343 ROM metadata models scanned.
[20:57:15.169] checksum module "subarudbw" loaded.
[20:57:15.169] checksum module "mitsucan" loaded.
[20:57:15.169] flashing tool "wrx02" loaded.
[20:57:15.169] flashing tool "wrx04" loaded.
[20:57:15.170] flashing tool "sti04" loaded.
[20:57:15.170] flashing tool "sti05" loaded.
[20:57:15.170] flashing tool "mitsukernel" loaded.
[20:57:15.170] flashing tool "mitsukernelocp" loaded.
[20:57:15.170] flashing tool "mitsubootloader" loaded.
[20:57:15.171] flashing tool "shbootmode" loaded.
[20:57:15.172] flashing tool "shaudmode" loaded.
[20:57:15.172] flashing tool "subarucan" loaded.
[20:57:15.173] flashing tool "mitsucan" loaded.
[20:57:23.305] A2WF200N (277 tables) inheriting 32BITBASE (662 tables)
[20:57:23.467] 1048576 byte image read.
[20:58:00.772] Using interface OpenPort 1.3 Subaru TX45pzIa4f59b7c9118c2abbb84aec0b1abea5acd6491085
[20:58:07.252] kernel get version
[20:58:07.641] SSM2 init
[20:58:07.792] SSM2 ECU ID is 45 12 78 31 06
[20:58:07.884] Requesting Seed...
[20:58:07.935] Sending Key...
[20:58:08.582] writing kernel area addr: FFFF3000 len: 0D00
[20:58:08.582] SSM2 write kernel ram block addr: FFFF3000 len: 0080
[20:58:08.682] SSM2 write kernel ram block addr: FFFF3080 len: 0080
[20:58:08.782] SSM2 write kernel ram block addr: FFFF3100 len: 0080
[20:58:08.882] SSM2 write kernel ram block addr: FFFF3180 len: 0080
[20:58:08.982] SSM2 write kernel ram block addr: FFFF3200 len: 0080
[20:58:09.082] SSM2 write kernel ram block addr: FFFF3280 len: 0080
[20:58:09.182] SSM2 write kernel ram block addr: FFFF3300 len: 0080
[20:58:09.282] SSM2 write kernel ram block addr: FFFF3380 len: 0080
[20:58:09.382] SSM2 write kernel ram block addr: FFFF3400 len: 0080
[20:58:09.482] SSM2 write kernel ram block addr: FFFF3480 len: 0080
[20:58:09.582] SSM2 write kernel ram block addr: FFFF3500 len: 0080
[20:58:09.682] SSM2 write kernel ram block addr: FFFF3580 len: 0080
[20:58:09.782] SSM2 write kernel ram block addr: FFFF3600 len: 0080
[20:58:09.882] SSM2 write kernel ram block addr: FFFF3680 len: 0080
[20:58:09.982] SSM2 write kernel ram block addr: FFFF3700 len: 0080
[20:58:10.082] SSM2 write kernel ram block addr: FFFF3780 len: 0080
[20:58:10.182] SSM2 write kernel ram block addr: FFFF3800 len: 0080
[20:58:10.282] SSM2 write kernel ram block addr: FFFF3880 len: 0080
[20:58:10.382] SSM2 write kernel ram block addr: FFFF3900 len: 0080
[20:58:10.482] SSM2 write kernel ram block addr: FFFF3980 len: 0080
[20:58:10.582] SSM2 write kernel ram block addr: FFFF3A00 len: 0080
[20:58:10.682] SSM2 write kernel ram block addr: FFFF3A80 len: 0080
[20:58:10.782] SSM2 write kernel ram block addr: FFFF3B00 len: 0080
[20:58:10.882] SSM2 write kernel ram block addr: FFFF3B80 len: 0080
[20:58:10.982] SSM2 write kernel ram block addr: FFFF3C00 len: 0080
[20:58:11.082] SSM2 write kernel ram block addr: FFFF3C80 len: 0080
[20:58:11.618] kernel get version
[20:58:11.629] kernel version is : OpenECU Subaru SH7058 OCP Kernel V1.06
[20:58:11.629] reading kernel comm buffer size
[20:58:11.644] comm buffer size set to 512
[20:58:11.644] reading kernel flash buffer size
[20:58:11.658] flash buffer size set to 4096
[20:58:11.658] -- test flashing image to ECU memory --
[20:58:12.059] -- comparing ECU flash memory pages to image file --
[20:58:12.065] seg start len ecu CRC32 img CRC32 same?
[20:58:12.077] readback mismatch
[20:58:12.077] error reading CRC!
[20:58:12.077] interface close
[20:58:12.079] interface close
I'm using 1.41 as I was never able to get 1.42 to work at all. The drivers seemed incompatible with my OS (Vista Home Premium.) I find it odd that when installing 1.41 (i've done this many times to try and alleviate the above error) that I get a message regarding "known driver incompatibility with the version of Windows XP." Funny because, again, I'm on a Vista OS. Once the install is complete I'm able to pull the ROM, log and use things like Merchgod's Learning View, however I always get the same above message when trying to do a test flash. When I install 1.42 over top of 1.41 or completely fresh from the ground up, the drivers never work and the system ends up not recognizing the usb device. I also find it odd that with 1.41 installed now, I no longer get the message about a newer version of ECUflash being available upon opening the program. Any insight appreciated.
