[11:12:02.744] EcuFlash Version 1.42.2595
[11:12:02.744] OS Version Windows Vista
[11:12:02.744] Qt Version 4.5.0
[11:12:02.754] 56 memory models read.
[11:12:02.754] scanning for metadata models in C:/openecu/rommetadata
[11:12:02.937] 455 ROM metadata models scanned.
[11:12:02.937] checksum module "subarudbw" loaded.
[11:12:02.937] checksum module "mitsucan" loaded.
[11:12:02.938] flashing tool "wrx02" loaded.
[11:12:02.938] flashing tool "wrx04" loaded.
[11:12:02.938] flashing tool "sti04" loaded.
[11:12:02.938] flashing tool "sti05" loaded.
[11:12:02.938] flashing tool "mitsukernel" loaded.
[11:12:02.938] flashing tool "mitsukernelocp" loaded.
[11:12:02.938] flashing tool "mitsubootloader" loaded.
[11:12:02.938] flashing tool "shbootmode" loaded.
[11:12:02.940] flashing tool "shaudmode" loaded.
[11:12:02.940] flashing tool "subarucan" loaded.
[11:12:02.940] flashing tool "mitsucan" loaded.
[11:12:10.312] Using interface OpenPort 1.3 Universal TX29VMKC29cb74d55517ba01031e19e62f4e11b679a6d6a7
[11:12:20.926] sending init sequence 1 (0001)
[11:12:21.956] got 0x05 response
[11:12:21.956] sending init sequence 2
[11:12:21.966] got 0x1B response
[11:12:21.966] sending init sequence 3
[11:12:22.338] entering bootloader
[11:12:22.339] sending kernel size (3560)
[11:12:22.359] sending kernel load address (0xFFFF8800)
[11:12:22.380] uploading kernel
[11:12:22.952] verifying kernel checksum response
[11:12:22.953] kernel valid
[11:12:23.154] kernel get version
[11:12:23.164] kernel version is : OpenECU Mitsubishi SH7052 Kernel V1.06SPD_FRK wrote:Ok, checked pin voltage now. With key "on" and cable hooked up, I get 4.68 volts. Once I do a test write and it does the init sequence voltages goes to 13.11, however I am still getting blank screen when trying to read from the Ecu.
SPD_FRK wrote:I can do that tonight for you when I am home. It basically pulls up a window that says "Read" which is grayed out and cannot be clicked, and second button is "Cancel." The window that comes up is blank like it should have something showing in it, I will get a screenshot tonight for you though.
rommetadatac:\Program Files\OpenECU\EcuFlash\rommetadata
