can't communicate with 04 wrx
PostPosted: Sat Jan 24, 2009 6:09 pm
by strogg
i plugged in the jumper block thing, and then read the ecu a couple days ago, so i know it works.
now today, i tried reflashing the ecu since i finished up with my mods. this is what happens
[17:20:13.656] Version 1.40.2178
[17:20:13.671] 19 memory models read.
[17:20:13.671] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[17:20:14.109] 320 ROM metadata models scanned.
[17:20:14.109] checksum module "subarudbw" loaded.
[17:20:14.109] flashing tool "wrx02" loaded.
[17:20:14.109] flashing tool "wrx04" loaded.
[17:20:14.109] flashing tool "sti04" loaded.
[17:20:14.109] flashing tool "sti05" loaded.
[17:20:14.109] flashing tool "mitsukernel" loaded.
[17:20:14.109] flashing tool "mitsukernelocp" loaded.
[17:20:14.109] flashing tool "shbootmode" loaded.
[17:20:14.109] flashing tool "shaudmode" loaded.
[17:20:14.109] flashing tool "subarucan" loaded.
[17:20:20.859] A4TF520F (324 tables) inheriting 16BITBASE (495 tables)
[17:20:20.937] XPT2520G (3 tables) inheriting A4TF520F (495 tables)
[17:20:21.015] 196608 byte image read.
[17:20:25.921] J2534 API Version: 04.04
[17:20:25.921] J2534 DLL Version: 0.50.2176 Oct 20 2008 17:50:12
[17:20:25.921] Device Firmware Version: 1.03.2380
[17:20:28.187] kernel get version
[17:20:28.781] SSM2 init
[17:20:29.484] SSM2 init
[17:20:30.187] SSM2 init
[17:20:30.875] SSM2 init
[17:20:31.562] SSM2 init
[17:20:32.250] SSM2 init
[17:20:32.937] SSM2 init
[17:20:33.640] SSM2 init
[17:20:34.343] SSM2 init
[17:20:35.031] SSM2 init
[17:20:35.828] interface close
[17:20:35.937] interface close
read or write is the same thing. it just won't communicate. whether the jumper block is in or not doesn't matter, same error message. with the ignition off it's also the same thing. is there something i'm missing?
