cant connect to 04 STI
PostPosted: Fri Jan 09, 2009 10:11 am
by taylor
[10:19:54.156] Using interface OpenPort 1.3 Subaru TX47pPN81aecb4d9a1d6a8225f564f84f5bcfdacbaef2534
[10:19:55.671] kernel get version
[10:19:56.062] SSM2 init
[10:19:56.218] SSM2 ECU ID is 2E 12 49 53 06
[10:19:56.296] Requesting Seed...
[10:19:56.343] Sending Key...
[10:19:56.390] interface close
keep getting this error.. any help?
green connector connected, no other clip for the plugs.
Re: cant connect to 04 STI
PostPosted: Wed Jan 14, 2009 12:55 am
by AlGontsov
You must press the read button before starting of fans, i.e. within first 1-2 seconds.
Also you may try to find another connectors or reading-flashing method.
PostPosted: Thu Jul 16, 2009 2:41 am
by Xisoka
I have the same problem with JDM STi 2006...
unable to connect.
PostPosted: Fri Oct 09, 2009 6:35 pm
by luizguccione
I have the same problem. I've tested on 4 JDM Imprezas. 1 WRX and 3 STIs. Cannot read ecu with EcuFlash. When reading from my 02 USDM WRX, everything works great (read, flash, log).
