Flashing a map in a different ecu
Thu Dec 25, 2008 3:13 pm
by xav
Is it possible to scribe with Ecuflash a JDM sti map (A4TJ111B) for exemple in a 16b EDM sti ecu ?
Re: Flashing a map in a different ecu
Sat Dec 27, 2008 3:37 am
by ®@©E®
I started similar thread on RomRaider, but forum seems to be down now, so I can't give you a link. Short answer, you can flash any rom with same flash method, car would probably start and tere would be CELs, sometimes a lot
Sat Dec 27, 2008 10:15 pm
by AlGontsov
You must open an
original ROM and make the same chenges in the corresponded fields or use copy-paste from one to another if x and y axis of maps are equal. And then it should be work.
Of course flashing another ROM to ECU can bring a lot of troubles
