Hanging on read ecu ecuflash v 1.40 on Evo 9
Postby Bigdon » Wed Nov 26, 2008 12:15 am
I’m having a problem with v 1.40, its just hanging when I ask it to read my Evo 9 ecu. It has read it before fine (maybe using an oldefr version of ecuflash.
I was wondering if its driver problem? In particular with the tactrix cable running as a comms serial port as that’s where I had it throw up a windows message about not being able to find drivers that better match the ones I already had?
EvoScan was still running ok though.
Bigdon
Re: Hanging on read ecu ecuflash v 1.40 on Evo 9
Postby evo400 » Tue Feb 03, 2009 5:52 am
I has the same problem.
Now i need to use 1.3cable for loging with evoscan 2.5 and 2.0cable for flashing with 1.40Ecuflash, stupid but true
You need to use 1.29a + evoscan + 1.3cable with no trouble
evo400
