Ecuflash post 1.29 pegging processor on read/write
Postby danl » Mon Oct 13, 2008 6:31 am
I think this has been mentioned before but it still hasn't been addressed in the newest version that was released the other day, 1.39. For some reason some Taxtrix cables have a different serial number scheme that these newer versions are not compatible with. The "fix" as you would call it is to rewrite a certain part of the memory as you load ecuflash. Every different version requires a new fix:
http://forums.evolutionm.net/showthread ... cable+hack
It seems simple and easy enough for this bug to be resolved in future issues of ecuflash, especially since the problem has been diagnosed.
thanks,
dan
danl
Postby markeddy » Mon Oct 13, 2008 4:20 pm
1.39 is still causing 100% CPU Peg.
1.39 is currently installing the x64 64-bit drivers instead of the x86 32-bit drivers.
Any ideas on when these issues will be resolved????
markeddy
