Won't Read ECU
Won't Read ECU
Postby Otto Performance » Fri Aug 08, 2008 10:08 am
After I select the car and press read ecu it goes through everything then has an error and says it had no response to any know code. What is this or what am I doing wrong?
[12:07:42.083] Version 1.35.1650
[12:07:42.085] 11 memory models read.
[12:07:42.086] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[12:07:42.197] 250 ROM metadata models scanned.
[12:07:42.197] checksum module "subarudbw" loaded.
[12:07:42.198] flashing tool "wrx02" loaded.
[12:07:42.198] flashing tool "wrx04" loaded.
[12:07:42.198] flashing tool "sti04" loaded.
[12:07:42.198] flashing tool "sti05" loaded.
[12:07:42.198] flashing tool "mitsukernel" loaded.
[12:07:42.198] flashing tool "mitsukernelocp" loaded.
[12:07:42.198] flashing tool "shbootmode" loaded.
[12:07:51.179] Using interface OpenPort 1.3b Universal TX28Ar15af5474d51d60f06e5fb4a26f6e36c15b93b9fe09
[12:07:56.613] sending init sequence 1 (0001)
[12:07:59.883] sending init sequence 1 (0003)
[12:08:03.152] sending init sequence 1 (FFFF)
[12:08:05.896] no response to any known code
[12:08:05.900] interface close
[12:08:05.910] interface close
Otto Performance
Postby Jon [in CT] » Fri Aug 08, 2008 2:39 pm
Looks like you're trying to read a Mitsubishi. Browse this thread:
http://forums.openecu.org/viewtopic.php?t=1097
Postby ~BoOsTeR~ » Wed Aug 13, 2008 5:28 pm
Unless you are familiar with the known patches, roll back to 1.34 or something previous. Delete all cable drivers, as well.
~BoOsTeR~
