cboles wrote:It depends on how the chip was erased. Have you erased the boot mode flash as well? If so, you could only reprogram the chip in a prom type programmer. If not, you should still be able to upload a kernel, only the ID code will have changed from 00 01 to FF FF, since those locations in the main flash will have become erased. The Evo is very safe from failed flashing because the bootloader is in a completely different memory area than the main flash block.
Hey Guys,
I've been lurking for quite some time and, well, now I have a question.
There seems to be a ton of info on loading your own write/erase controller program, although Renesas doesn't seem to say where they are writing the program to. Do you know where in mem the boot loader code has placed mitsu's write/erase controller program? A read out of ROM has not shown it's location, although I may be missing something. Has anyone been able to address the boot loader code or mitsu's write/erase controller program directly or indirectly?
Thanks,
Mr.Evo
