Test Flash error on 02 WRX help please
Postby mjsiii » Fri Feb 29, 2008 7:59 pm
I'm trying to reflash my 02 wrx with the latest stock revision (a4sge01c as i gather). I was able to pull the rom from my ecu no problem (it's a a4sge00c). Anyway, i went in for a test flash and here's the log with the error i got:
[19:26:28.694] Using interface OpenPort 1.3 Subaru TX47CB5z1ec3f4d53675fc04f0e2b5621966815fa5e3edb3
[19:26:35.827] denso02_bootloader_cmd_start
[19:26:36.059] writing kernel area addr: 020000 len: 0664
[19:26:37.995] kernel get version
[19:26:38.016] kernel version is : OpenECU Subaru HC16 Kernel V1.05
[19:26:38.016] reading kernel comm buffer size
[19:26:38.027] comm buffer size set to 512
[19:26:38.027] reading kernel flash buffer size
[19:26:38.048] flash buffer size set to 4096
[19:26:38.048] Test flashing image to ECU memory...
[19:26:38.448] comparing ECU flash memory pages to image file
[19:26:38.449] seg start len ecu CRC32 img CRC32 same?
[19:26:38.781] FB01 00000000 00004000 D69BEB35 95EECB0A NO
[19:26:39.124] FB02 00004000 00004000 BEC1C9EF BEC1C9EF YES
[19:26:39.457] FB03 00008000 00004000 ED12BFA3 ED12BFA3 YES
[19:26:39.790] FB04 0000C000 00004000 F65FEBBC F65FEBBC YES
[19:26:40.123] FB05 00010000 00004000 71FA9AE0 71FA9AE0 YES
[19:26:40.446] FB06 00014000 00004000 9447808A 9447808A YES
[19:26:40.779] FB07 00018000 00004000 DC572A50 DC572A50 YES
[19:26:41.102] FB08 0001C000 00004000 36BC4A8F 36BC4A8F YES
[19:26:41.435] FB09 00028000 00004000 CB2938E5 1BA0DB8A NO
[19:26:41.758] FB10 0002C000 00004000 6671B0DD A532AC32 NO
[19:26:42.059] reading ecu programming voltage
[19:26:42.080] programming voltage is 11.99 volts
[19:26:42.080] kernel flash disable
[19:26:42.091] rkrv: can't read response payload
[19:26:42.091] interface close
[19:26:42.108] interface close
The green connectors were firmly in place. (ECU was flashing and the rad fans were cycling when i clicked the ignition on to check for this.) I have the reflash jumper which was also definitely firmly in place and i was using a 1.3 cable with version 1.34 ecuflash. In addition, i have the latest versions of the subaru xml definitions.
The laptop i'm using has never had a previous version of ecu flash on it.
What does this error mean and how can i overcome it so i can upgrade to the latest wrx flash?
Thanks in advance,
Mike
mjsiii
