I' VE TRY TO READ MY CAR EUROPEAN VERSION STI '02 I HAVE CONNECT THE GREEN CONNECTORS UNDER THE DAS, AND BY PASS(WHITE CONNECTORS), BUT DON'T READ I HAVE USED ALL PROTOCOLS
SEE LOG DETAILS
[13:48:45.961] Version 1.34.1435
[13:48:45.971] 11 memory models read.
[13:48:45.971] scanning for metadata models in C:/Archivos de programa/OpenECU/EcuFlash/rommetadata
[13:48:46.492] 219 ROM metadata models scanned.
[13:48:46.492] checksum module "subarudbw" loaded.
[13:48:46.492] flashing tool "wrx02" loaded.
[13:48:46.492] flashing tool "wrx04" loaded.
[13:48:46.492] flashing tool "sti04" loaded.
[13:48:46.492] flashing tool "sti05" loaded.
[13:48:46.492] flashing tool "mitsukernel" loaded.
[13:48:46.492] flashing tool "mitsukernelocp" loaded.
[13:48:46.492] flashing tool "shbootmode" loaded.
[14:01:46.092] Using interface OpenPort 1.3 Universal TX27XeBw7458f4d5f732236f1c88dbbafac36aa4d650a688
[14:01:49.787] denso02_bootloader_cmd_start
[14:01:51.019] denso02_bootloader_cmd_start
[14:01:52.251] denso02_bootloader_cmd_start
[14:01:53.473] denso02_bootloader_cmd_start
[14:01:54.694] denso02_bootloader_cmd_start
[14:01:55.135] kernel get version
[14:01:55.466] interface close
[14:01:55.486] interface close
[14:02:06.892] Using interface OpenPort 1.3 Universal TX27XeBw7458f4d5f732236f1c88dbbafac36aa4d650a688
[14:02:09.556] denso02_bootloader_cmd_start
[14:02:10.768] denso02_bootloader_cmd_start
[14:02:11.989] denso02_bootloader_cmd_start
[14:02:13.211] denso02_bootloader_cmd_start
[14:02:14.433] denso02_bootloader_cmd_start
[14:02:14.873] kernel get version
[14:02:15.204] interface close
[14:02:15.224] interface close
[14:02:25.819] Using interface OpenPort 1.3 Universal TX27XeBw7458f4d5f732236f1c88dbbafac36aa4d650a688
[14:02:28.022] SSM2 init
[14:02:28.223] SSM2 ECU ID is 29 44 59 41 05
[14:02:30.276] interface close
[14:02:30.286] interface close
[14:02:57.324] Using interface OpenPort 1.3 Universal TX27XeBw7458f4d5f732236f1c88dbbafac36aa4d650a688
[14:02:59.117] SSM2 init
[14:02:59.297] SSM2 ECU ID is 29 44 59 41 05
[14:02:59.297] SSM2 read ram byte addr: 000061
[14:02:59.367] ECU is in test mode
[14:02:59.438] SSM2 init
[14:02:59.618] SSM2 ECU ID is 29 44 59 41 05
[14:03:01.671] interface close
[14:03:01.681] interface close
[14:03:10.784] Using interface OpenPort 1.3 Universal TX27XeBw7458f4d5f732236f1c88dbbafac36aa4d650a688
[14:03:12.817] SSM2 init
[14:03:13.017] SSM2 ECU ID is 29 44 59 41 05
[14:03:15.060] interface close
[14:03:15.070] interface close
[14:03:26.546] Using interface OpenPort 1.3 Universal TX27XeBw7458f4d5f732236f1c88dbbafac36aa4d650a688
[14:03:29.391] denso02_bootloader_cmd_start
[14:03:30.602] denso02_bootloader_cmd_start
[14:03:31.814] denso02_bootloader_cmd_start
[14:03:33.026] denso02_bootloader_cmd_start
[14:03:34.238] denso02_bootloader_cmd_start
[14:03:34.668] kernel get version
[14:03:34.999] interface close
[14:03:35.009] interface close
[14:03:44.903] Using interface OpenPort 1.3 Universal TX27XeBw7458f4d5f732236f1c88dbbafac36aa4d650a688
[14:03:56.129] denso02_bootloader_cmd_start
[14:03:57.341] denso02_bootloader_cmd_start
[14:03:58.553] denso02_bootloader_cmd_start
[14:03:59.764] denso02_bootloader_cmd_start
[14:04:00.976] denso02_bootloader_cmd_start
[14:04:01.407] kernel get version
[14:04:01.737] interface close
[14:04:01.747] interface close
[14:04:10.359] Using interface OpenPort 1.3 Universal TX27XeBw7458f4d5f732236f1c88dbbafac36aa4d650a688
[14:04:15.357] denso02_bootloader_cmd_start
[14:04:16.578] denso02_bootloader_cmd_start
[14:04:17.800] denso02_bootloader_cmd_start
[14:04:19.012] denso02_bootloader_cmd_start
[14:04:20.224] denso02_bootloader_cmd_start
[14:04:20.664] kernel get version
[14:04:21.005] interface close
[14:04:21.025] interface close
[14:05:55.130] Using interface OpenPort 1.3 Universal TX27XeBw7458f4d5f732236f1c88dbbafac36aa4d650a688
[14:05:58.976] denso02_bootloader_cmd_start
[14:06:00.187] denso02_bootloader_cmd_start
[14:06:01.399] denso02_bootloader_cmd_start
[14:06:02.611] denso02_bootloader_cmd_start
[14:06:03.823] denso02_bootloader_cmd_start
[14:06:04.253] kernel get version
[14:06:04.594] interface close
[14:06:04.614] interface close
[14:06:12.886] Using interface OpenPort 1.3 Universal TX27XeBw7458f4d5f732236f1c88dbbafac36aa4d650a688
[14:06:14.999] SSM2 init
[14:06:15.179] SSM2 ECU ID is 29 44 59 41 05
[14:06:15.179] SSM2 read ram byte addr: 000061
[14:06:15.259] ECU is not in test mode
[14:06:24.743] interface close
[14:06:48.998] Using interface OpenPort 1.3 Universal TX27XeBw7458f4d5f732236f1c88dbbafac36aa4d650a688
[14:06:50.690] SSM2 init
[14:06:50.870] SSM2 ECU ID is 29 44 59 41 05
[14:06:50.870] SSM2 read ram byte addr: 000061
[14:06:50.940] ECU is in test mode
[14:06:51.041] SSM2 init
[14:06:51.241] SSM2 ECU ID is 29 44 59 41 05
[14:06:53.284] interface close
[14:06:53.294] interface close
[14:07:09.627] Using interface OpenPort 1.3 Universal TX27XeBw7458f4d5f732236f1c88dbbafac36aa4d650a688
[14:07:12.391] denso02_bootloader_cmd_start
[14:07:13.613] denso02_bootloader_cmd_start
[14:07:14.825] denso02_bootloader_cmd_start
[14:07:16.036] denso02_bootloader_cmd_start
[14:07:17.248] denso02_bootloader_cmd_start
[14:07:17.679] kernel get version
[14:07:18.009] interface close
[14:07:18.019] interface close
[14:07:28.174] Using interface OpenPort 1.3 Universal TX27XeBw7458f4d5f732236f1c88dbbafac36aa4d650a688
[14:07:42.775] SSM2 init
[14:07:42.965] SSM2 ECU ID is 29 44 59 41 05
[14:07:42.965] SSM2 read ram byte addr: 000061
[14:07:43.045] ECU is in test mode
[14:07:43.135] SSM2 init
[14:07:43.316] SSM2 ECU ID is 29 44 59 41 05
[14:07:45.359] interface close
[14:07:45.369] interface close
[14:07:56.415] Using interface OpenPort 1.3 Universal TX27XeBw7458f4d5f732236f1c88dbbafac36aa4d650a688
[14:07:59.729] denso02_bootloader_cmd_start
[14:08:00.941] denso02_bootloader_cmd_start
[14:08:02.153] denso02_bootloader_cmd_start
[14:08:03.405] denso02_bootloader_cmd_start
[14:08:04.616] denso02_bootloader_cmd_start
[14:08:05.047] kernel get version
[14:08:05.377] interface close
[14:08:05.387] interface close
[14:08:17.385] Using interface OpenPort 1.3 Universal TX27XeBw7458f4d5f732236f1c88dbbafac36aa4d650a688
[14:08:19.868] SSM2 init
[14:08:20.059] SSM2 ECU ID is 29 44 59 41 05
[14:08:22.122] interface close
[14:08:22.142] interface close
[14:08:31.275] Using interface OpenPort 1.3 Universal TX27XeBw7458f4d5f732236f1c88dbbafac36aa4d650a688
[14:08:34.720] denso02_bootloader_cmd_start
[14:08:35.931] denso02_bootloader_cmd_start
[14:08:37.143] denso02_bootloader_cmd_start
[14:08:38.355] denso02_bootloader_cmd_start
[14:08:39.567] denso02_bootloader_cmd_start
[14:08:39.997] kernel get version
[14:08:40.328] interface close
[14:08:40.338] interface close
[14:09:12.804] Using interface OpenPort 1.3 Universal TX27XeBw7458f4d5f732236f1c88dbbafac36aa4d650a688
[14:09:15.228] SSM2 init
[14:09:15.418] SSM2 ECU ID is 29 44 59 41 05
[14:09:15.418] SSM2 read ram byte addr: 000061
[14:09:15.498] ECU is not in test mode
[14:09:40.054] interface close
[14:09:46.553] Using interface OpenPort 1.3 Universal TX27XeBw7458f4d5f732236f1c88dbbafac36aa4d650a688
[14:09:48.456] SSM2 init
[14:09:48.646] SSM2 ECU ID is 29 44 59 41 05
[14:09:48.646] SSM2 read ram byte addr: 000061
[14:09:48.726] ECU is in test mode
[14:09:48.826] SSM2 init
[14:09:49.006] SSM2 ECU ID is 29 44 59 41 05
[14:09:51.059] interface close
[14:09:51.069] interface close
[14:10:28.934] Using interface OpenPort 1.3 Universal TX27XeBw7458f4d5f732236f1c88dbbafac36aa4d650a688
[14:10:31.137] SSM2 init
[14:10:31.327] SSM2 ECU ID is 29 44 59 41 05
[14:10:31.327] SSM2 read ram byte addr: 000061
[14:10:31.397] ECU is not in test mode
[14:10:51.697] interface close
