All,
After flashing my EDM MY06 WRX I turned off the ignition as usual and disconnected the Green connectors. I then turned the ignition ON and tried to start the car. It is cranking but won't start!! I also cannot connect to the ECU by any means. If I connect the Green connectors back again it will not flash the CEL and go into bootmode. What to do?? I'm immobilised!! Please help.
Best Regards,
Jasper.
