reading/writing problem
Postby sureshot007 » Mon Jan 21, 2008 1:52 pm
When I try to read or write to an 03 WRX, I get this:
[16:09:53.822] Using interface OpenPort 1.3 Subaru TX46P7iWd1afb4d5cb2fdefcbbc1174b0e871c8f1590e3cf
[16:09:58.819] denso02_bootloader_cmd_start
[16:10:00.051] denso02_bootloader_cmd_start
[16:10:01.283] denso02_bootloader_cmd_start
[16:10:02.514] denso02_bootloader_cmd_start
[16:10:03.746] denso02_bootloader_cmd_start
[16:10:04.197] kernel get version
[16:10:04.527] interface close
[16:10:04.537] interface close
The computer and cable are fine, as I used them on my car with no issues. Any other ideas you can think of?
sureshot007
Postby japerformance » Thu Jan 24, 2008 7:23 am
i am getting exactly the same any ideas anyone
japerformance
Postby sureshot007 » Wed Jan 30, 2008 4:46 pm
Someone has to know what this means.
sureshot007
Postby RE02XY » Thu Feb 07, 2008 3:03 am
Having the same problem with my car and a friends same message cant seem to get it to start without going into diagnostics mode. Next try is to delete all files and programs from computer then reinstall, it worked once before for me. If you have sorted your problems out please let me know how you did it.
RE02XY
Postby sureshot007 » Thu Feb 07, 2008 4:25 am
But my laptop and cable work just fine on my 02 wrx - I just flashed it yesterday.
sureshot007
Postby isis » Mon Mar 24, 2008 9:09 am
I too get this same problem. I'm having issues with bugeyes only. A USDM 2002 WRX and USDM 2003 WRX wagon. My 2005 WRX wagon and my friend's 2005 USDM STI read and write just fine with this same hardware. Please, someone put up an answer if you find one. I'm confused, but they aren't my cars, so I don't want to put much time into a solution if I don't need to. :)
isis
Postby uter8 » Mon Mar 24, 2008 7:09 pm
yeah me too, same problem 2004 wrx aus version, any ideas anyone?? have removed and reinstalled software, still same, tried another laptop, still same!! help!!
uter8
Postby kebert » Fri Apr 04, 2008 6:27 pm
I have the same problem!!! 2002 WRX Aus version! HELP!!!
Can read, but cannot write.
kebert
Postby swifty1981 » Sun Apr 06, 2008 7:59 am
i also have the same problem on a 2001 bugeye wrx
swifty1981
Postby claudefrog » Sun Apr 06, 2008 2:32 pm
got the same problem
MY2002 STI UK
been told its a timing issue.. meant to turn ignition on and immediately press on on the read button on ECUflash... howevr I cannot get it to work at all
claudefrog
Postby Alex Maroto » Thu May 29, 2008 7:05 pm
I used to have the same trouble, but it was a timing trouble...
YOu have to have your software ready to download or upload and connectors in place before turning the key to "on" position
I mean as you put the key on, clic on the mouse to let software communicate with car ECU
It works!! :o
Alex Maroto
Postby Phoenix* » Sun Jun 15, 2008 6:18 am
I have the same problem with my 2005 WRX.
Timing the ignition turn, with the read command shouldn't be causing a problem. My mates cable and sofware seems to be reading/flashing my ecu with no poblems...irrelevant of when the ignition is turned on...hmmm :?
Phoenix*
