1.34 upgrading over older version =failure
Sat Dec 01, 2007 8:31 pm
by brucer
can't get a once used laptop with 1.29 to work with 1.34.
removed everything ecuflash related without success. unfortunately even removed older version, so can't work with that laptop. xp platform
another laptop without earlier version ecuflash works well with 1.34. xp platform
Sun Dec 02, 2007 8:48 am
by Freon
What happens? Error message?
Sometimes problems with old stuff in "C:\Program Files\OpenECU\EcuFlash\rommetadata" directory can keep ECUflash from running properly (either won't start, or crashes immediately). Try installing to a new directory (like /ecuflash2), or if you don't have any custom files in /EcuFlash directory just delete it and reinstall.
Tue Dec 04, 2007 8:12 pm
by brucer
hmmm, I'll try a new directory.
I did go through and remove as much as I could find. Right through the ecuflash folders, thinking I could do a clean re-install. drivers and all.
what happens is simple enough. I go to do an upload and the box comes up empty, there is just nothing to choose from. ie evo8, suburu, etc.
Tue Jan 08, 2008 7:33 pm
by brucer
still at a loss the box to choose a car ecu from is blank.
Fri Jan 11, 2008 10:23 am
by Freon
Do you have anything in this directory?
C:\Program Files\OpenECU\EcuFlash\rommetadata\read templates
The XML in that directory should be what is used to populate the box that comes up when you try to read.
Fri Jan 11, 2008 8:33 pm
by brucer
the read templates folder contains files of 1 KB.
Sat Jan 12, 2008 12:36 pm
by Freon
Ok, that's what you should see. 8-9 XML files, all very small. Perhaps NTFS file permissions are set wrong and ecuflash.exe cannot read the files?
Can you try reinstalling ECUflash, but select a new directory. Say,
C:\Program Files\OpenECU\EcuFlash2\
Instead of
Then try running it from the new directory.
Sat Jan 12, 2008 1:34 pm
by brucer
thanks,
I've tried the second directory with no effect.
luckily for me I have another laptop, just would like to use my old brick instead of the loosie goosie laptop.
it all started when I tried to upload a 1.33 ecuflash on a 1.29 install. I then removed everything and tried installing several times. Flushing every ecuflash related file. Then I tried moving a working program from another computer and still no change.
Sun Jan 27, 2008 12:03 pm
by brucer
you know what, I think I have been misrepresenting what is going on.
I get to the window that should say," turn on key...etc, but that window is blank.
