Using ecuflash for both evo's and Sti's
Postby got boost? » Fri Nov 16, 2007 12:38 pm
I've always used ecuflash V1.3 for tuning evo's and zero problem, but yesterday i read an MY06 EDM STI, saved the rom and then modified the rev limiter to 7500 (7000 Stock), wrote to ECU with no problem but when we did a road test nothing happened, rev limiter is still in 7000. So i installed ecuflash 1.34 and worked fine, but now when i try to read an already saved Evo rom, stationay rev limiter shows "2" !!!!!!!! and all the parameters show weird things.
Please i need some help with this, i need to be able to flash both cars.
Now i installed V1.3 again and worked fine with the evo rom, but wrong with sti's.
Thanks guys.!
got boost?
Postby Freon » Sat Nov 17, 2007 10:41 am
Drive by wire closes the throttle body at red line on most cars. You need to modify the throttle tables as well to raise the rev limit.
