ECUFlash 1.34 incorrectly reporting newer versions.
Postby LEEVO » Mon Nov 05, 2007 3:21 pm
When v1.34 starts, it (annoyingly) displays the following text:
"A new version is available!
There is a new version of EcuFlash available. Please visit openecu.org to upgrade to the newest version. Changes in the newest versions are as follows:
2007-10-01: Version 1.35 released
Subaru metatdata updated to version 0.79b
removed test mode detection altogether as it causes problems on many ECUs
fix to HC16 kernel to allow bootloader communications to complete before starting kernel
fix bug causing extra data to be sent when loading some kernels
improve KWP2000 resynchronization
2007-09-06: Version 1.32 released
removed test mode detection for 2005+ DBW Subarus because some models do not have a test mode connector"
...1.35 hasn't been released yet and 1.32 is older than 1.34!
I think the '1.35' is a typo, which should read '1.33'......therefore, no version updates should be displayed on startup!
LEEVO
Postby Jorge T » Thu Nov 08, 2007 6:07 pm
After a reboot it will go away
Jorge T
