Need Help with Def hex file for JDM Evo 8 MR
Postby wrx-blue-mica » Mon Oct 01, 2007 1:40 am
Hi
I have problem to open the Hex file for JDM EVO 8 MR.
The hex file already downloaded succesfully with Ecuflash v1.32 but the file couldn't be open. Needs definition file for MN 191140, E6T 34886 H.
I also attach the Hex file.
Please help me with this problem.
Thank you for your attention & help
Regards
Setiawan
STock Afi Evo 8.hex
(256 KiB) Downloaded 737 times
wrx-blue-mica
Postby wrx-blue-mica » Tue Oct 02, 2007 2:19 am
Anybody please help me. Thanks
wrx-blue-mica
Postby cossie1 » Tue Oct 02, 2007 8:44 am
Here you go
96260007.xml
(10.34 KiB) Downloaded 595 times
cossie1
Postby wrx-blue-mica » Thu Oct 04, 2007 9:09 pm
cossie1 wrote:Here you go
Cossie1, Thank u, thank u, and thank u! .. I'll try it.
One more thing, where/how should I install it to make it work?
Once again Thank you
wrx-blue-mica
Postby salex » Thu Oct 04, 2007 10:24 pm
If you have a look at your openecu\ecuflash folder, there is a rommetadata folder in there. Put the definition in there, under the Evo subfolder.
salex
Postby wrx-blue-mica » Sun Oct 07, 2007 7:48 am
salex wrote:If you have a look at your openecu\ecuflash folder, there is a rommetadata folder in there. Put the definition in there, under the Evo subfolder.
got it ... thanks Salex!!
wrx-blue-mica
Postby qoncept » Sun Oct 07, 2007 4:05 pm
Off topic does anyone have the installer for 1.32?
Postby wrx-blue-mica » Tue Oct 16, 2007 1:06 am
Hi Cossie
I have tried using your XML but the table open with many funky numbers.
Did I do something wrong?
wrx-blue-mica
Postby cossie1 » Tue Oct 16, 2007 3:26 am
Works fine for me, with ecuflash 1.33.
Try deleting the definition from your romdata folder.
Then start ecuflash
Then close it and add in the xml added above again.
Then restart ecuflash.
cossie1
Postby wrx-blue-mica » Thu Oct 18, 2007 11:15 pm
cossie1 wrote:Works fine for me, with ecuflash 1.33.
Then start ecuflash
Hi Cossie1
Yessss .... Finally it's work after I upgrade to v1.33 (use to be v1.30).
Now the tables open nicely.
Many thanks to your help!!!
wrx-blue-mica
Postby cossie1 » Fri Oct 19, 2007 12:48 am
Glad you got it sorted mate
cossie1
