Help! Can read but can't write 05 lgt at
Postby blkbxlgt » Sat Sep 08, 2007 9:36 am
I can pull the rom with no problem, but I can't get it to flash
When I try to flash, it looks like everything is fine but as soon as I get kernel flash enable it stops and says there is an error please look at the log, but looking at the log I can't find any errors
I've tried several version of ecuflash and they all do the same thing on different computers 1.28, 1.29 1.30 1.31 and 32 on a clean windows install
Tried different timing with the ignition switch, click OK at the same time, wait one fan cycle, and anywhere in between no luck
Tried to set the flash to sti04, but no luck, it won't even open the kernel
Even tried to change the memmap from SH7058 to 55 can't even open the map but no supprise there
Current ECU version A2WC510C
Cable 1.3U
Here's a copy of the log
[16:31:48.468] Version 1.30.1095
[16:31:48.468] 8 memory models read.
[16:31:49.796] 146 ROM metadata models read.
[16:31:49.796] checksum module "subarudbw" loaded.
[16:31:49.796] flashing tool "wrx02" loaded.
[16:31:49.796] flashing tool "wrx04" loaded.
[16:31:49.796] flashing tool "sti04" loaded.
[16:31:49.796] flashing tool "sti05" loaded.
[16:31:49.796] flashing tool "mitsukernel" loaded.
[16:31:49.796] flashing tool "mitsukernelocp" loaded.
[16:31:49.796] flashing tool "mitsubootloader" loaded.
[16:31:56.593] 1048576 byte image read.
[16:32:03.359] SSM2 init
[16:32:03.515] [FF] A2 10 11 2F 12 50 52 06 73 FA CB A6 2B 81 FE A8
00 00 00 60 CE 54 F9 B1 E4 00 0C 20 00 00 00 00
00 DC 00 00 5D 1F 30 C0 F2 26 00 00 43 FB 00 E1
00 00 00 00 00 00 C1 F0
[16:32:03.531] SSM2 ECU ID is 2F 12 50 52 06
[16:32:03.531] SSM2 cmd_0x81
[16:32:03.578] SSM2 cmd_0x83
[16:32:03.625] SSM2 challenge-response
[16:32:03.687] SSM2 challenge is 86 F3 20 30
[16:32:03.687] SSM2 response is 00 48 94 21
[16:32:03.734] SSM2 cmd_0x10
[16:32:04.109] SSM2 validating kernel ram area addr: FFFF3000 len: 0C98
[16:32:04.156] writing kernel area addr: FFFF3000 len: 0C98
[16:32:04.359] SSM2 write kernel ram block addr: FFFF3000 len: 0080
[16:32:04.687] SSM2 write kernel ram block addr: FFFF3080 len: 0080
[16:32:04.984] SSM2 write kernel ram block addr: FFFF3100 len: 0080
[16:32:05.312] SSM2 write kernel ram block addr: FFFF3180 len: 0080
[16:32:05.625] SSM2 write kernel ram block addr: FFFF3200 len: 0080
[16:32:05.937] SSM2 write kernel ram block addr: FFFF3280 len: 0080
[16:32:06.250] SSM2 write kernel ram block addr: FFFF3300 len: 0080
[16:32:06.562] SSM2 write kernel ram block addr: FFFF3380 len: 0080
[16:32:06.890] SSM2 write kernel ram block addr: FFFF3400 len: 0080
[16:32:07.187] SSM2 write kernel ram block addr: FFFF3480 len: 0080
[16:32:07.500] SSM2 write kernel ram block addr: FFFF3500 len: 0080
[16:32:07.812] SSM2 write kernel ram block addr: FFFF3580 len: 0080
[16:32:08.171] SSM2 write kernel ram block addr: FFFF3600 len: 0080
[16:32:08.484] SSM2 write kernel ram block addr: FFFF3680 len: 0080
[16:32:08.812] SSM2 write kernel ram block addr: FFFF3700 len: 0080
[16:32:09.125] SSM2 write kernel ram block addr: FFFF3780 len: 0080
[16:32:09.437] SSM2 write kernel ram block addr: FFFF3800 len: 0080
[16:32:09.765] SSM2 write kernel ram block addr: FFFF3880 len: 0080
[16:32:10.078] SSM2 write kernel ram block addr: FFFF3900 len: 0080
[16:32:10.406] SSM2 write kernel ram block addr: FFFF3980 len: 0080
[16:32:10.718] SSM2 write kernel ram block addr: FFFF3A00 len: 0080
[16:32:11.046] SSM2 write kernel ram block addr: FFFF3A80 len: 0080
[16:32:11.359] SSM2 write kernel ram block addr: FFFF3B00 len: 0080
[16:32:11.687] SSM2 write kernel ram block addr: FFFF3B80 len: 0080
[16:32:12.015] SSM2 write kernel ram block addr: FFFF3C00 len: 0080
[16:32:12.328] SSM2 write kernel ram block addr: FFFF3C80 len: 0018
[16:32:14.640] SSM2 entering kernel
[16:32:14.875] kernel get version
[16:32:14.906] kernel version is : OpenECU Subaru SH7058 OCP Kernel V1.02
[16:32:14.953] reading kernel comm buffer size
[16:32:14.968] comm buffer size set to 512
[16:32:14.984] reading kernel flash buffer size
[16:32:15.000] flash buffer size set to 4096
[16:32:15.015] Flashing image to ECU memory...
[16:32:15.421] comparing ECU flash memory pages to image file
[16:32:15.437] segment len ecu CRC32 img CRC32 same?
[16:32:15.468] FB01 00001000 A1D86B9A A1D86B9A YES
[16:32:15.531] FB02 00001000 8F101821 8F101821 YES
[16:32:15.562] FB03 00001000 4224D3B7 4224D3B7 YES
[16:32:15.609] FB04 00001000 A5E9ED3A A5E9ED3A YES
[16:32:15.656] FB05 00001000 7F8F423D 7F8F423D YES
[16:32:15.718] FB06 00001000 5A0ED3AD 5A0ED3AD YES
[16:32:15.765] FB07 00001000 0ABF2651 0ABF2651 YES
[16:32:15.812] FB08 00001000 7A766AEB 7A766AEB YES
[16:32:16.156] FB09 00018000 CBBF1911 CBBF1911 YES
[16:32:16.578] FB10 00020000 FF5B05A6 FF5B05A6 YES
[16:32:17.000] FB11 00020000 CD40F30C CD40F30C YES
[16:32:17.437] FB12 00020000 E0592CD4 E0592CD4 YES
[16:32:17.859] FB13 00020000 A14D4B80 A14D4B80 YES
[16:32:18.281] FB14 00020000 154803CC 154803CC YES
[16:32:18.718] FB15 00020000 02123D02 2941A93B NO
[16:32:19.140] FB16 00020000 47D36C2E 47D36C2E YES
[16:32:19.140] kernel flash enable
Anyone as any ideas?
blkbxlgt
